Post by dickie on Sept 20, 2020 20:56:42 GMT
Hi Folks, I have had to scratch my entry due to having a damaged finger, So someone else will get Lucky and have a go at the hill.
Post by binner on Sept 21, 2020 8:32:03 GMT
thats a shame, I was looking forward to putting a face to name.
get well soon
Post by boggissimo on Sept 21, 2020 11:45:46 GMT
Hi Folks, I have had to scratch my entry due to having a damaged finger, So someone else will get Lucky and have a go at the hill. Was that *after* you told your wife? Coincidence?
Post by Zed. on Sept 21, 2020 12:53:46 GMT
Hi Folks, I have had to scratch my entry due to having a damaged finger, So someone else will get Lucky and have a go at the hill. Was that *after* you told your wife? Coincidence? Rich.
Post by dickie on Sept 21, 2020 20:18:57 GMT
My Wife is the one that took me to get my finger X rayed. At least it did not show up as break on the X-ray.
Post by nookey on Sept 24, 2020 10:46:52 GMT
I wish I'd entered this one instead of the Abingdon CAR-nival, although the CAR-nival is two sprints in one.
Post by boggissimo on Sept 28, 2020 11:26:19 GMT
Had a lot of fun at Wiscombe yesterday. It's a long way for me to go for 4 minutes of track time though! I came 8th in class, but fastest 1600 Mazda. Since the class was 1400–1800cc there were a couple of VW Golfs and a couple of Elises.
Will try to sort a video upload soon.
Post by binner on Sept 29, 2020 7:30:04 GMT
it was a great day out. I managed a 49.8 not bad for my first weekend there. boggissimo were you in the blue 1.6 no 37 and 37A ? my fastest run
Post by boggissimo on Sept 29, 2020 8:20:22 GMT
it was a great day out. I managed a 49.8 not bad for my first weekend there. boggissimo were you in the blue 1.6 no 37 and 37A ? my fastest run That's a good time, my best was 52.3, on my second timed run. I was going faster by the Esses on the final run but cocked up Sawbench, so ended up a bit slower. I was #30, the white one. Were you #407 then?
I'm annoyed that I had my normal road tyres on the car expecting it to be wet, everyone else was on semi-slick trackday tyres! Got loads of wheelspin out of both hairpins. Video coming soon!
Post by boggissimo on Sept 29, 2020 9:24:01 GMT
Here's my vid (all three runs together):
Will sort out individual runs with speed and timing overlays at some point...
Post by Zed. on Sept 29, 2020 9:50:12 GMT
it was a great day out. I managed a 49.8 not bad for my first weekend there. boggissimo were you in the blue 1.6 no 37 and 37A ? my fastest run looked good you need a better diff, too much wheel-lifting Here's my vid (all three runs together): Will sort out individual runs with speed and timing overlays at some point... another good run, I'm not jealous (as I stayed in the house feeling sorry for myself working on my Passat...) your car seems higher geared than binners? re. leaving the start / first corner I'm glad theres no footage of me rallying on youtube for anyone to criticise - oh bugger, there is go to 42.30.... was a 200mile roadrally around Epynt ranges, jogularity @ start (for the historics) and a blast over the randes on os maps embarassing Rich.
Post by boggissimo on Sept 29, 2020 10:23:19 GMT
I've found livestream footage from Sunday: I'm at ?t=270 (first run), ?t=4288 (second run) and ?t=8608 (third run)
I'm getting lots of inside wheel spin on the hairpins, might just be unloaded but shouldn't the LSD be doing something about that?
Post by Zed. on Sept 29, 2020 10:53:04 GMT
I'm getting lots of inside wheel spin on the hairpins, might just be unloaded but shouldn't the LSD be doing something about that? what diff have you got? a torsen will loose drive when a wheel is lifted, a plate lsd will try to drive (depending on setup & wear) Rich.
Post by binner on Sept 29, 2020 10:58:31 GMT
My car is a 2.5 with the 3.6 torsen and the 6 speed box hence the slightly lower gearing. I was on road tyres , Michelin PS3 , as the Bristol Motor club mx5 challenge is list 1a so no semi slicks. Yes I was no 407. If your car is still stock power then join the challenge next year details here bristolmc.org.uk/mx5challenge/and here www.mx5challenge.co.uk/or if you have modified you engine there is this bristolmc.org.uk/2020-bristol-two-litre-cup/We are hoping to get an entry to wiscombe again, normally its manor farm.
Post by binner on Sept 29, 2020 11:06:38 GMT
I'm getting lots of inside wheel spin on the hairpins, might just be unloaded but shouldn't the LSD be doing something about that? what diff have you got? a torsen will loose drive when a wheel is lifted, a plate lsd will try to drive (depending on setup & wear) Rich. A plate LSD would be a Kaaz the or similar ? teh only problem with those is the cost ;-)
