Post by dickie on Sept 13, 2020 14:51:45 GMT
Hi Folks, I have entered my first ever sprint which will give the Mongrel and myself a test, ( I expect the Mongrel has Bigger Balls than me ) This will also be my first event of the year !!!
Its at Spitfire Raceway on one of the runways at Perranporth Airfield. I am looking forward to being a Hooligan on the tarmac. Truro and District Motor Club are organising the event which is closed to spectators.
Post by Zed. on Sept 13, 2020 15:56:58 GMT
gopro fitted in the car yet? if not then why not?? if you don't have one I'll send you one Rich.
Post by dickie on Sept 13, 2020 18:18:04 GMT
Hi Rich, I have the Lidl version and its Poo ! I think I will invest in a proper one.
Post by dickie on Sept 13, 2020 18:55:36 GMT
Got one on overnight should be at work on Tuesday for me !
Post by dickie on Sept 16, 2020 20:26:10 GMT
Go Pro now ready for action at the weekend. I will try it out on the drive to work.
Post by Zed. on Sept 16, 2020 22:10:05 GMT
Go Pro now ready for action at the weekend. I will try it out on the drive to work. just be a good boy otherwise you'll be supplying your own incriminating evidence Rich.
Post by dickie on Sept 19, 2020 16:03:46 GMT
Hi Folks, I have just got home from todays sprint at Perranporth Airfield. A great day out only spoilt by a light shower to slow us down a bit. The car went well, The driver needs to find the brake points and turn in points. I might improve tommorow ! Results here for today. So you can all see the varity of vehicles and times. The other Mazda Eunos is stripped out with bucket seat and harness, I have more power but a stock interior/seat and seatbelt with CG Lock irp-cdn.multiscreensite.com/d1646039/files/uploaded/SwtResultsFor200919.pdfI will attempt to upload some footage later.
Post by Zed. on Sept 19, 2020 16:24:44 GMT
The car went well, The driver needs to find the brake points and turn in points. I might improve tommorow did the car break? did the car act as you wanted? did you enjoy? then... can anything be improved or are you happy with the results? Rich.
Post by dickie on Sept 19, 2020 16:43:06 GMT
Hi Rich, The Mongrel went well, The driver needs Bigger Balls, ( It is a road car first though and I need to bring it home undamaged ) The other Eunos lives on a recovery truck and is a competition car first and road car second. The car is very balanced with its extended lower ball joints, only a bit of understeer when I went too fast into a crossover ( The Cones Got Scared ) I found no power oversteer out of the hairpins either so happy with my DIY which way to point the wheels. got too much wheelspin off the line in the damp.
If you have a look at the Truro and District Motor Club site you should be able to find the course layout. This was on a very bumpy but grippy undulating runway with quite an elevation change. I get to try and improve my efforts tommorow. The only problem with the car was it spat out most of the power steering fluid. !!!
Post by Zed. on Sept 19, 2020 17:54:23 GMT
The only problem with the car was it spat out most of the power steering fluid. !!! easily fixable larger pas fluid reservoir should do this or eps Rich.
Post by dickie on Sept 19, 2020 19:11:43 GMT
Or not overfilling it !!!! I am attempting to put an in car Vid on U Tube, It looks like it will take a long time.
Post by Zed. on Sept 19, 2020 19:48:14 GMT
Or not overfilling it !!!! pas fluid loss seems to be a common issue, think the reservoir's design doesn't help as does (or doesn't?) its size? if it was taller then maybe more effective at de-aeriation and less volume filled with foam so less or no overflow maybe Rich.
Post by dickie on Sept 21, 2020 20:25:36 GMT
The Sunday was a good days fun apart from a badly swollen finger on my left hand ! I am disapointed with the goprohero8 the videos are very jerky and seem to jump back and forwards. I am wondering if I have got a Duff one !!!
Post by boggissimo on Sept 22, 2020 15:55:13 GMT
Even jerky video is better than no video
Post by FFS Corders on Sept 22, 2020 18:19:15 GMT
The Sunday was a good days fun apart from a badly swollen finger on my left hand ! I am disapointed with the goprohero8 the videos are very jerky and seem to jump back and forwards. I am wondering if I have got a Duff one !!! What SD card is with it? If it isn't Class 10 you will struggle to get the video to record well and play back
