Post by dickie on Sept 22, 2020 19:31:44 GMT
Hi Corders, Its the SD card that came with the Gopro bought from the gopro website. Sandisk extreme 32gb. I just ran with the settings on the camera, I have had a look on the web and it seems I might have needed to change the settings. The definition might be too high for windows 10 to cope with, I started to load a bit onto Utube it took 45mins to load 4 percent. so I stopped it.
Post by FFS Corders on Sept 22, 2020 19:42:33 GMT
Ah yes, too much quality for poor windows to keep up!
Post by dickie on Sept 24, 2020 16:33:05 GMT
Hi Folks, Apart from the Camera bug. It was a great couple of days learning About the new Mongrel The power delivery was excellent, I was a bit shy of using max revs though. I fitted extended lower camber arms on the front of the car and it has heavy duty anti-roll bars front and back with the stock Bilstein shocks and springs, IL motorsports bushes + Diff bushes with MSM engine mounts. I did a DIY Alignment. The car was very neutral with this set up and NS2R rubber. No tail happiness out of the hairpins, mild understeer when I bowled into the crossover too fast. The back end squatted down and the front lifted off the line without too much wheelspin. My main fault was slowing down way to early for the corners. I was amazed at how different sprinting is to doing a Hillclimb. The other mazdas entered, One was a stripped out 1800cc that had a lot of development He was 4 seconds faster than me, The other was a Mk2.5 1600 turbo again he was 3 to 4 seconds faster than me. I am hoping to do a few more sprints next year as well as some hillclimbs.
