Post by wannabe on Jul 3, 2021 1:01:43 GMT
Post by dadbif on Jul 3, 2021 8:22:58 GMT
Post by howardb66 on Jul 3, 2021 8:50:26 GMT
From what I understand, E10 is replacing the regular grade fuel. As you say, run your MX5 on ‘premium’ & it’ll be fine.
Post by Zed. on Jul 3, 2021 10:47:35 GMT
STOP SCAREMONGERING use it & stop panicing.... only possible worry is that rubber fuel pipes and components could errode but their easily replaced. also, higher ethenol content can allow tuning for more torque (if you've a suitable setup) but at the cost of economy... can also use a 'Flexfuel' sensor if you want to be clever Rich.
Post by wannabe on Jul 3, 2021 15:54:48 GMT
STOP SCAREMONGERING use it & stop panicing.... only possible worry is that rubber fuel pipes and components could errode but their easily replaced. also, higher ethenol content can allow tuning for more torque (if you've a suitable setup) but at the cost of economy... can also use a 'Flexfuel' sensor if you want to be clever Rich. So only risk of fuel leakage and a massive fire? lol
Post by Zed. on Jul 3, 2021 16:07:32 GMT
STOP SCAREMONGERING use it & stop panicing.... only possible worry is that rubber fuel pipes and components could errode but their easily replaced. also, higher ethenol content can allow tuning for more torque (if you've a suitable setup) but at the cost of economy... can also use a 'Flexfuel' sensor if you want to be clever Rich. So only risk of fuel leakage and a massive fire? lol you're gonna die one day you should have an extinguisher in the car if you're Safety conscious:P and the time taken for your ~30 year old fuel-system components to degrade you'll probably not own the car anyway if you're worried then replace the old hoses / 'O' rings and pressure-reg and be happy that all this might have been needing replacement due to age anyway? normal petrol has had 5% ethenol (E5). for years, the scaremongering damage started years ago.... not forgetting the water in the steel fuel tank Rich.
Post by Zed. on Jul 4, 2021 19:18:36 GMT
Post by wannabe on Jul 4, 2021 21:37:30 GMT
That does look useful, thank you! Some quoting that may be relevant follows!
Post by wannabe on Jul 4, 2021 21:45:40 GMT
I forgot to say - I only every use Super so hopefully I will only die a fiery death half as quickly as those using Regular
Post by dadbif on Jul 4, 2021 21:49:22 GMT
So do I, plus an additive, we’ll burn together…
Post by Zed. on Jul 4, 2021 21:49:36 GMT
I forgot to say - I only every use Super so hopefully I will only die a fiery death half as quickly as those using Regular Live dangerously Rich.
Post by dadbif on Jul 10, 2021 15:06:00 GMT
Public information film
Post by niklas on Jul 10, 2021 17:17:24 GMT
Just use it. And if worried, change to gates barrier.
We switched years ago in Sweden without ill effects.
Also. When tuning my car i picked up 18nm at the wheels from only switching from petrol to e85. No tuning it whatsoever.
Ethanol is king.
Post by Zed. on Jul 19, 2021 15:15:20 GMT
Post by Johnnie Sport Black on Jul 27, 2021 8:29:43 GMT
Only ever use Tesco 99 RON.
