Post by esjayar on Aug 1, 2021 11:59:11 GMT
Hi. New to forum and would appreciate any help. I need to replace the engine on my mk2 year 2000 'W' 1.8 nb. What are my options, Does it have to be the same engine or can I use any others? There seem to be more 1.6 engines available then the 1.8, could I fit one of these? What are the engine identification numbers I should be looking for?
Post by Zed. on Aug 1, 2021 12:21:13 GMT
There seem to be more 1.6 engines available then the 1.8 where? all the engines I see for sale are the 1.8 as to interchangability, obviously like-for-like is easiest but double-check sensors & fittings Rich.
Post by FFS Corders on Aug 1, 2021 14:58:31 GMT
You're after a BP4W 1.8 from an early NB so any with the old style numberplate.
1.6 is not a straight swap and neither is the vvt engine from facelift NBs but there's guide out there on the internet for doing them
Post by warpspeed on Aug 2, 2021 6:48:11 GMT
Replacing a 22 year old engine with another 22 year old engine may not be the perfect solution to all your problems. If you can find a low mileage engine at a good price, that would be great. But the one you buy may be in as bad a condition or worse than the one you already have.
It may be worth considering a freshen up or a rebuild.
