Post by dickie on Sept 12, 2021 18:16:22 GMT
Hi Folks
I have finally got around to installing a variable brake balance valve on the Rs Mongrel. I have installed it in place of the OEM valve utilising one of the OEM banjos and a second one very kindly donated by Zed. This allows the valve to be installed vertically beside the master cylinder. It also fits beside the Pipercross filter on my ITBs. I had to bend the Davefab brace a little and bend the brake pipes a little, I also countersank the fixing hole on the valve and used an A4-70 csk cap screw. ( Thanks Work )
The valve kit I used came from Bofi Racing.
Thanks again to Zed for the second Banjo and Copper Washers.
Crumpets
Insert witty remark here...
Post by Crumpets on Sept 12, 2021 21:16:47 GMT
Very neat install!
Post by boggissimo on Oct 1, 2021 8:19:58 GMT
How do you find it? Been thinking about getting one of these for ages, how much difference does it make?
Post by dickie on Oct 1, 2021 18:05:02 GMT
Hi, I have not driven the car since I installed it. Mx5s have a lot of front bias in standard trim, I intend to get a bit more rear bias. I have put it under the bonnet because I would not have a chance to fiddle in competition. My install was a lazy one with no messing with the pipes apart from a small amount of bending. You might find it benificial to cockpit mount for road rallys or fit a cable to twiddle it with. Car is on Sorn at the moment as I don't need it for commuting. Time to save up for a 2.5" exhaust system to go with the Simpson Racing Manifold.
