Post by Zed. on Jan 30, 2022 13:21:17 GMT
change of plan & direction so these are available. pair of Fidanza 94018 Adjustable Cam Pulleys, fit NA/NB 1.6L & 1.8L engines (only the exhaust cam on vvt engnes) these are marked with 94018 that corrisponds with Fidanza's p/number for the Mazda engine, oddly these are slightly different designs as one has larger holes in the central section than the other they've been used but not done much work as the outer-pulley's teeth have no wear in the anodising & just the lightest hint of marking that tallies with a belt's position... the centers have witness-marks from a cam-bolt's washer and also from the end of a cam. they come with an M5 allenbolt (mushroom-head) and plain nut as fastening (with a flatwasher over the slot & springwasher to lock) but I'm not a fan of plain nuts / springwashers... bought some 'K-nuts', these are the 'K-nuts' with inbuilt washer. kl-projects.be/products/khxw-m5-080/the image shows how small the nut is - M5 thread & 6mm across the flats for a 6mm spanner / socket. tried one K-nut on a pulley to compare against the 'standard' Fidanza offering. also lighter! obviously it's up to the purchaser to decide on using these fastners (but I was going to) I've deburred the centres as explained in my thread mighty5s.com/post/50443/threadthese are £191 each from Moss. www.moss-europe.co.uk/fidanza-adjustable-cam-gears-mx-5-mk2.html£130 SOLD the pair. Collection prefered located near Swansea, South Wales. but will post with RMSD (recorded, tracked & signed for 24 hour) for an extra £10. Rich.
Post by Fizbne on Mar 1, 2022 12:50:38 GMT
Howdy,
Have you still go these?
Ta!
x
Post by Zed. on Mar 18, 2022 22:39:56 GMT
Howdy, Have you still go these? Ta! x sorry sold elsewhere forgot to update this advert thread... Rich.
