oggs
Post by oggs on Jan 22, 2024 17:54:50 GMT
Hi everyone, does anyone know where/if I can get inner wheel arch panels for an NC. Having started digging away at rust I am now left with a large gap between the wheel arch and the boot floor. Also, is this sort of thing likely to be an MOT fail? The suspension turrets forward of the wheel arch rust areas are solid, as are the subframe mounts inboard of the wheel arches on the underside.
Fingers crossed!
Post by Zed. on Jan 24, 2024 20:04:22 GMT
is this sort of thing likely to be an MOT fail? The suspension turrets forward of the wheel arch rust areas are solid, as are the subframe mounts inboard of the wheel arches on the underside. iirc, any corrosion / holes within 30cm / 1' are a fail (testers descression dependant ) as to repair panels, I've no idea unless you visit Mazda steelers or Mx5parts etc for genuine sections to be trimmed? Rich.
