Post by steamo on May 21, 2016 17:42:03 GMT
I've got P5 Puredrive coilovers fitted to my car and there is a slight knock that sounds like it's coming from the topmounts. It's not catastrophic but is a bit annoying. As the previous owner fitted them in not even sure what the top mounts are like (I'm thinking they're standard style ones?) and I've not had time to whip them off as yet. I did try nipping the locknuts on the shock shaft but that's made no difference.
Just wondering if anyone else has had similar or at least knows what the topmounts are like. Cheers
Post by gman77 on May 21, 2016 21:53:01 GMT
Not sure with p5s but on normal t mount If gasket is missing does make a racket Had this on my first 5 . So is gasket between t mount and under Side of suspension strut there ! Small very thin like plastic Hth
Post by steamo on May 22, 2016 16:53:47 GMT
Cheers for that I'll whip one off tomorrow and see what's what. I'm pretty sure they are standard type top mounts.
Post by gman77 on May 23, 2016 16:40:27 GMT
How did you get on !
Post by steamo on May 23, 2016 18:33:14 GMT
Well I whipped them off today, gasket was present on both sides. Top mounts were new, must have been replaced when the coilovers were fitted a few thousand miles ago. I put a smidge of rubber grease on the bushes themselves for good measure and wanged them back on.
Noise is still there, I'm just going to live with it, it's not intrusive (only really happens at slow speed on rippely surfaces) and I'm happy that there is nothing amiss. I think it might just be the shocks over coming the initial 'sticktion' (excuse the MTB terminology) when they start to move.
