Post by NurseHolliday on Jun 13, 2016 14:12:05 GMT
My launch control and flatshift have stopped working. I think it's the wiring to the on/off switch but it could be the clutch switch? If it was the clutch switch would the car still work fine?
Apologies for the n00b question.
Post by Horney on Jun 13, 2016 15:20:40 GMT
Yes. Clutch switch failure normally means odd things happen with the idle when you depress the clutch when on standard ECU. On aftermarket it does nothing except when used for LC.
