Post by myothercarsa2cv on Sept 18, 2016 13:20:55 GMT
Took the chassis bracing off to start the diff removal process. What a ballache. Exhaust I managed to get one bolt half undone. It will go eventually, but Christ it's hard work.
Post by V6 on Sept 18, 2016 14:21:56 GMT
I guess you'll be using some copper grease when you re-assemble then!
Post by myothercarsa2cv on Sept 18, 2016 15:51:26 GMT
Don't suppose it'll make any difference on the exhaust, but yes loads on the brace!
Post by wannabe on Sept 18, 2016 18:22:27 GMT
Never managed to get my car to the top of the axel stands before! This might well be a dumb question... ... but are those stands holding up the chassis rails? I'm sure I read that it's not a good idea and the jacking points on the sills should be used?? (Although I'm not quite sure how one would jack it up using the jacking points and then remove said jack to swap it for an axle stand... lol)
Post by Dweenimus on Sept 18, 2016 18:29:56 GMT
Never managed to get my car to the top of the axel stands before! This might well be a dumb question... ... but are those stands holding up the chassis rails? I'm sure I read that it's not a good idea and the jacking points on the sills should be used?? (Although I'm not quite sure how one would jack it up using the jacking points and then remove said jack to swap it for an axle stand... lol) You're correct. They are on the double walled bits of the rails. You'll see they are a bit thicker on both ends.
Post by wannabe on Sept 19, 2016 8:14:50 GMT
This might well be a dumb question... ... but are those stands holding up the chassis rails? I'm sure I read that it's not a good idea and the jacking points on the sills should be used?? (Although I'm not quite sure how one would jack it up using the jacking points and then remove said jack to swap it for an axle stand... lol) You're correct. They are on the double walled bits of the rails. You'll see they are a bit thicker on both ends. Ahhh, clever! I would check mine but I can't currently get my jack under it... lol
Rasc
Nutz troll apparently
Post by Rasc on Sept 19, 2016 13:33:05 GMT
Went for a drive..
Post by V6 on Sept 23, 2016 15:10:19 GMT
I also went for a drive today. Since getting my tracking tweaked and going two clicks harder on the rear dampers my steering has sharpened up a lot. It darts into corners more eagerly and the back end feels lighter, so it moves about more, meaning I have to steer into it sometimes. All good fun
Post by wannabe on Sept 23, 2016 18:31:04 GMT
I also went for a drive today. Since getting my tracking tweaked and going two clicks harder on the rear dampers my steering has sharpened up a lot. It darts into corners more eagerly and the back end feels lighter, so it moves about more, meaning I have to steer into it sometimes. All good fun Should be interesting come winter - frost, rain, diesel on damp roundabouts, dead leaves, snow, ice...
Post by V6 on Sept 23, 2016 19:20:03 GMT
Should be great fun
Post by Dweenimus on Sept 25, 2016 14:56:36 GMT
Tried removing diff. Didn't work so dropped the whole subframe. All to get one bloody ppf bolt off! Now to find the time to convert to manual!
Post by Horney on Sept 25, 2016 16:51:55 GMT
Went to the Sussex Brekkie Meet, got home and sold the VR Ltd.
Post by FFS Corders on Sept 25, 2016 18:17:06 GMT
grats
Post by Horney on Sept 27, 2016 9:45:42 GMT
Post by Dweenimus on Oct 3, 2016 12:00:35 GMT
It's all going down in bumblebee land today! 10 points to whoever guesses correctly
