Post by minty on Feb 28, 2017 21:55:07 GMT
As some of you may know, my car (apparently a low mileage 1.8 r-ltd) had the lowest WHP figures at Skuzzles, apart from a pickup truck, a canoe estate car(hehe- though only just) and Jordan's silver 1.6 (but she weighs half of me so is super fast anyway)
It produced more torque than bhp (102/96) and my limiter kicked in at only just over 6k rpm. Have sent Skuzzle an email, but in the mean time any thoughts on what's up with my little blue diesel mx5??
cheers
Post by wannabe on Feb 28, 2017 22:58:10 GMT
Just to ask the question, is it (to the best of your knowledge) completely standard?
Post by Woofwoof on Feb 28, 2017 23:17:48 GMT
Cam timing out since last belt change?
Post by Rickster on Mar 1, 2017 6:46:35 GMT
Timing??
Post by Rickster on Mar 1, 2017 6:47:13 GMT
Get a compression test done
Post by Horney on Mar 1, 2017 7:57:31 GMT
My money is on the cam belt being a tooth out.
Post by minty on Mar 1, 2017 9:13:14 GMT
Just to ask the question, is it (to the best of your knowledge) completely standard? Haha, no idea - cant find any evidence to suggest it isn't though.
@horney - is the one tooth out thing easy to check, or is it a case of actually re-fitting it?
Post by Horney on Mar 1, 2017 9:20:53 GMT
Cam cover off and count ribs between the top pulleys. I can't remember off the top of my head how many it should be. If that's OK then all front covers off and check the marks all line up.
Post by martiny on Mar 1, 2017 10:48:38 GMT
Cam cover off and count ribs between the top pulleys. I can't remember off the top of my head how many it should be. If that's OK then all front covers off and check the marks all line up. Nineteen ribs between the marks on the cam pulleys. Plus of course piston 1 should be at top dead centre when the marks are at 12 o'clock. Or to make it easier to see, take off the next cover down and check the 4 o'clock mark on the intake and 8 o'clock mark on the exhaust cam wheel match the line on the back plate.
Post by baconsarnie on Mar 1, 2017 10:55:45 GMT
Cam cover off and count ribs between the top pulleys. I can't remember off the top of my head how many it should be. If that's OK then all front covers off and check the marks all line up. 19 "teeth" Oh, beaten to it! ^^
Post by minty on Mar 1, 2017 11:48:28 GMT
Thank you chaps, that sounds like something I can do P.S would any of this explain why I only hit just over 6k rpm though??
Post by wannabe on Mar 1, 2017 12:19:22 GMT
I thought the rev limiter was ECU-controlled??
Post by martiny on Mar 1, 2017 15:42:02 GMT
Rev limiter is indeed ECU controlled. So that wouldn't explain a 6k limit. Maybe your rev counter under-reads (though I thought it was more common to over-read a little).
Coincidentally, many years ago I spent ages fruitlessly unpicking the ROM in my early 1.8 ECU and discovered that the "7,200 rpm" limit was actually set at 7,000 rpm.
Post by wannabe on Mar 1, 2017 19:16:12 GMT
Is there a crank angle sensor or something like that which sends engine speed or other info to the ECU?
Post by minty on Mar 1, 2017 21:40:23 GMT
The print out from the RR itself shows it dropping off the cliff at approx 6200rpm so don't think it's the rev counter. i
