Post by Oliver Rooney on May 2, 2017 17:47:19 GMT
I am looking into getting my diff welded, i wouldnt mind in a normal car, but does welding your once open diff rewin the handling the 5 is well kown for
I want to go to drift days but want to know if i can still go on track days without to much hassle from a welded diff ?
As the torsen is noe getting rare and expensive and a kazz 1.5 and 2 way lsds are 700 odd plus ?
Post by Oliver Rooney on May 2, 2017 17:47:55 GMT
Tbf no the open diff isnt the best in the first place lol !
Post by Horney on May 2, 2017 18:58:57 GMT
Welded diffs are not the best. DO you use the car not he road as a daily?
Also, what's the spec of your car? Engine, power, gearbox etc.
Post by Oliver Rooney on May 2, 2017 19:38:45 GMT
Welded diffs are not the best. DO you use the car not he road as a daily? Also, what's the spec of your car? Engine, power, gearbox etc. Hey its a 1996 1.8 uk spec bace modle no pas, 5 speed and an open diff, i dont use it as a daily but i want to be able to go drifting but at the same time i want to go on a few track days this year ? At the same time i dont want to destroy the handling, have been temped to buy an lexus is200 sport with an lsd just have to get over the mpg figures lol
Post by Oliver Rooney on May 2, 2017 19:41:00 GMT
Welded diffs are not the best. DO you use the car not he road as a daily? Also, what's the spec of your car? Engine, power, gearbox etc. Hey its a 1996 1.8 uk spec bace modle no pas, 5 speed and an open diff, i dont use it as a daily but i want to be able to go drifting but at the same time i want to go on a few track days this year ? At the same time i dont want to destroy the handling, have been temped to buy an lexus is200 sport with an lsd just have to get over the mpg figures lol Power is fairly standard bar a 4-2-1 exhaust manifold, decat, full stainless exhaust, intake ignition leads. when remeber to dig my timing light out i will advance the timing
Post by myothercarsa2cv on May 2, 2017 20:31:34 GMT
To weld the diff properly you'll need to drop it, dismantle, weld, reassemble and reinstall. Unless you're doing it all yourself, for the cost of paying someone to do it for you, you might as well buy a Torsen.
Post by Horney on May 2, 2017 20:52:22 GMT
For keeping costs low I'd look at picking up a VLSD from a 1.6 and using that, you'l need to swap the shafts and prop as well though.
4.3 Torsens are pretty hard to come buy at a reasonable price sadly.
Post by Oliver Rooney on May 3, 2017 4:17:42 GMT
To weld the diff properly you'll need to drop it, dismantle, weld, reassemble and reinstall. Unless you're doing it all yourself, for the cost of paying someone to do it for you, you might as well buy a Torsen. Yes i would take it apart myself and get a friend to weld it for me.
Post by Oliver Rooney on May 3, 2017 4:18:57 GMT
For keeping costs low I'd look at picking up a VLSD from a 1.6 and using that, you'l need to swap the shafts and prop as well though. 4.3 Torsens are pretty hard to come buy at a reasonable price sadly. Cheers i shall have a look around for the vlsd parts id need ! And yes last time i saw a torsen for sale it was 700 odd the same as kazz lol ! Getting a tad expensive lol
Post by myothercarsa2cv on May 3, 2017 6:51:43 GMT
If you're happy to rebuild the diff yourself, I have all the parts to make your own Torsen or welder. I only have a 4.1 CWP but you could get a Kia Sportage one (4.7) and build it up. Where are you?
Post by Horney on May 3, 2017 7:39:15 GMT
I have a working Super Fuji you can have for £150 as well. It's a 3.6 though, so again you'd want To swap the CWP from your current open diff into it.
Post by myothercarsa2cv on May 3, 2017 7:42:19 GMT
I'd be tempted by the 3.6 if you go for the Fuji Ollie...
Post by Oliver Rooney on May 3, 2017 18:11:42 GMT
I have a working Super Fuji you can have for £150 as well. It's a 3.6 though, so again you'd want To swap the CWP from your current open diff into it. Ah cool cheers where about are you baced ?and is their enough info online for swapping the cpw ?
Post by minty on May 3, 2017 19:19:54 GMT
I'd be tempted by the 3.6 if you go for the Fuji Ollie... Forgive me if I missed it, but is OP intending to stay NA? If so, has anyone fitted a 3.6 lsd and thought it improves an NA 5? Genuinly interested. Just seems wrong to me, but happy to be corrected.
Post by Horney on May 3, 2017 19:41:24 GMT
I have a working Super Fuji you can have for £150 as well. It's a 3.6 though, so again you'd want To swap the CWP from your current open diff into it. Ah cool cheers where about are you baced ?and is their enough info online for swapping the cpw ? The diff is at Skuzzles in Winchester.
