Post by Zed. on Jul 7, 2022 16:00:13 GMT
parcel by front door Rich.
Post by Zed. on Jul 7, 2022 18:13:37 GMT
so....... a box was opened... had stuff..... Owf uckinmuch? but, I knew the prices before ordering so no suprise there. now to consider the lower front wishbones other busness... had a different delivery. stuff. a thing. more of this when it gets built into another thing Rich.
Post by Zed. on Jul 10, 2022 21:38:21 GMT
been working so not much to share, had an hour earlier on the Kazz Lsd build but not mush progress (pigshead has first coat of black hammerite smooth and Lsd unit stripped / bearings pressed on) tries the Hispec 2 piston (ultralite2) caliper & Wilwood 'spot' handbrake caliper in an Enkei wheel to assess spoke clearance.... they fit. footbrake caliper, need to actually make the mount-bracket not just leave a piece of aluminium in there.... the 'spot' caliper for mecanical / cable handbrake (road mot test & Msauk competition legality) - the handbrake cable could mount on the top-bush area of the hub / upright.... clearance is clearance? clearance? better view.... another view showing clearance to outside of caliper & pad covering the disc. more to post soon but time passes.... Rich.
Post by dadbif on Jul 11, 2022 8:12:24 GMT
Time passes…. Men grow old, wither and die, yet your pile of components grows ever higher…. Careful you don’t fall off it and hurt yourself…😜
Post by thruxton on Jul 11, 2022 9:48:39 GMT
Hurtful….
Post by dadbif on Jul 11, 2022 9:49:58 GMT
Not meant to be, just concerned…🤣
Post by thruxton on Jul 11, 2022 10:37:00 GMT
Of course….
Post by Zed. on Jul 11, 2022 16:44:09 GMT
your pile of components grows ever higher…. build sub-assemblies then join the dots.... need toy-tokens to amass said sub-asemblies.... and while collecting said tokens think of better ways to complicate matters Careful you don’t fall off it and hurt yourself…😜 also, I'm fat enough to bounce unfortunately Rich.
Post by thruxton on Jul 11, 2022 17:22:10 GMT
It’s TRUE. I’ve been on Safari …. And Zed is the fattest thing I’ve ever seen!
I kid, because I love.
Post by dickie on Jul 11, 2022 20:42:50 GMT
I believe there is an ointment for Zeds Piles.
It used to be sold as Castrol R !!
Post by Zed. on Jul 11, 2022 21:16:23 GMT
And Zed is the fattest thing I’ve ever seen! definately the fattest I've ever been Rich. (102kg)
Post by Zed. on Jul 11, 2022 21:55:08 GMT
more faffin... building a diff.... sandblasted the pigshead (can see the errosion around the flange boltholes!) asa, like most diffs it was somewhat crusty black Hammerite smooth (free advertising?) this is the second coat, hopefully tomorrows sunlight will bake the paint to a good, hardwearing finish subject of diff... its a Kazz 1.5 way plate LSD the 'internals'. can see the 'ramps' that tighten the clutches on acceleration & deceleration (25/45 ramp angles if that means anything to you?) interestingly theres a ring of weld on both 'sunwheels' (the ones that connect to the driveshafts) - different designs / makers have different methods, the Kazz LSD has a good reputation so this will not be a problem more faffin to follow.... Rich.
Post by howardb66 on Jul 12, 2022 6:56:41 GMT
Diff is looking good Zed.. although I’m surprised at that sun wheel being welded. Hope it’s not a weakness.
Post by Zed. on Jul 12, 2022 16:02:35 GMT
Diff is looking good Zed. . although I’m surprised at that sun wheel being welded. Hope it’s not a weakness. it'll be fine, as you know Kazz have a great reputation hopefully Rich.
Post by batou on Jul 14, 2022 9:38:17 GMT
Ooofff what a box of bits, I think this is also the route I'll be going to be honest. I can't remember if you still have the 1.6 or 1.8 ring gear or not, my memorys a bit prarrie canoe but I'm sure there was something regarding silly final drive ratios and can't remember what you have in there. What else in the box and, how much more did this hurt the wallet compared to the wishbones?
