Post by dadbif on Oct 2, 2024 20:58:15 GMT
Do you have a target date when it will run?
Post by dickie on Oct 3, 2024 16:07:20 GMT
No Target Dates or even Target Year !!!
Post by dickie on Oct 5, 2024 10:22:20 GMT
Hi Folks, The donor head is now stripped down but I have left the valve guides in for the time being. They will get replaced with bronze ones later on. I will pressure wash it and try and get some time on one of the mills at work to do the inlet manifold face angle change next week. After the milling is done I will decide how to do the next step.
I am not sure what to do with the cams I took off the head !? They could be available to anyone that wants a pair to have re ground or I might just chuck the Exhaust Cam in my lathe and remove the end so that it can be used for an Exhaust to inlet Swap ( BP 4 W cams )
