Post by thruxton on Jan 23, 2021 13:18:18 GMT
I use to know things. Now I've forgotten and things have changed a lot in the last 20 + years.
Here is a question.
A 1999 MX-5 NB has its 1.8 engine swaped out for a 1988 engine still Mazda but a V6 one. Now when it comes to the MOT it use to be something like this.
The MOT emissions side of the test would be done as though the car was a 1988 car. Is this still the same now? And if so would that car then need a catalytic convertor?
Thank you in advance for any help here. Regards. Rich.
Post by Zed. on Jan 23, 2021 15:06:33 GMT
Now when it comes to the MOT it use to be something like this. The MOT emissions side of the test would be done as though the car was a 1988 car. Is this still the same now?I didn't think it ever was And if so would that car then need a catalytic convertor? erm, yes? the mot test requirement is based around the car, its age & what was fitted @ manufacture... something like (UK) vehicles built post '91 need a cat, a Japaneese import has the requirement relaxed a few years ('94??) as they weren't fitted untill then for jdm vehicles - or something like that if a car is made / registered after the relavant date it should have a cat fitted to pass the test... ^^OR have an empty cat body OR cat shaped dummy-cat over the pipe as an imitation there is an exception to this.... if the car is obviously heavily modified - as a stage rallycar for example. this relaxes the airbag necessity also Rich.
Post by dickie on Jan 23, 2021 15:16:31 GMT
Post by wannabe on Jan 23, 2021 15:36:24 GMT
I agree with the chaps above but I thought it might be '95 that you can get away with no Cat on an import. They should choose the emissions standards to test to from the chassis number. The JDM chassis numbers are different to the UK chassis numbers, so they shouldn't be able to find an import on the system - therefore pre-cat test only. (I think there's a thread on emissions standards somewhere on here, I'll have to try and find it.) I wasn't aware that one could get a test in accordance with the engine rather than the chassis - I'm pretty sure that would only work one way, in that they'd only test to a more modern standard rather than letting one put a 5.7 litre V8 with no cats into a Prius... (In fact, now I write that, I am sure I have seen regulations that says no car can have worse emissions than it came out of the factory with, hence no-one can convert an EV to ICE.)
Post by wannabe on Jan 23, 2021 15:40:52 GMT
