Rasc
Nutz troll apparently
Post by Rasc on May 28, 2016 10:48:05 GMT
How'd you retain the aircon with the turbo, Rasc ? The FM kit was already fitted when I bought the car. However the IC pipe goes through the inner wing and on the passenger side and misses the AC pump,etc. Build thread on Nutz has a pic of engine bay. www.mx5nutz.com/forum/index.php?showtopic=152271
Post by driftmonkey on May 29, 2016 8:28:11 GMT
Mk1 1.8 Gt2560r 14psi FM cast manifold, 2.5" downpipe, mid box, power xs 2.5" exhaust Evo 650cc injectors Walbro fuel pump Mish mash of pipework and an eBay intercooler.
Post by driftmonkey on May 29, 2016 8:58:08 GMT
Is everyone else limiting torque?
Post by niklas on May 29, 2016 14:41:30 GMT
Well, I am, still got more than you though (can't really run anymore before I go forged. it's a tracked car, e85 or not). edit, or actually, if your dyno is wheel/hub, we've got about equal torque, but I keep it high for longer.
Post by driftmonkey on May 29, 2016 18:06:30 GMT
Yeah that was my old car, at the wheels. Back to standard power on my latest car, I'll have more than my old car later in the year, this time with forged rods, last time was all standard internals.
Post by niklas on May 29, 2016 19:13:05 GMT
Yeah, I'm all standard internals as well. Will run it for a while. When I can't drive this faster, I'll forge. But that will be costly as it will see me upgrading a lot of stuff, so it's for some later time
Post by atlex on May 29, 2016 21:35:16 GMT
BTW do all dyno dynamics RRs do strictly WHP ?
Post by driftmonkey on May 29, 2016 22:35:38 GMT
I've got a sort of pact with a friend. These cars are meant to be cheap fun things, so the engine builds are just rods and standard rest, maybe headstuds.
I'd like about 275whp, so if any Americans are reading, that's over 300whp on your dyno readings.
I think you can make them give you a flywheel or wheel power figure, skuzzle normally uses whp.
Post by niklas on May 30, 2016 5:16:56 GMT
I've got a sort of pact with a friend. These cars are meant to be cheap fun things, so the engine builds are just rods and standard rest, maybe headstuds. I'd like about 275whp, so if any Americans are reading, that's over 300whp on your dyno readings. Following with interest. I thought about doing this for a long time. About the second paragraph, thats with dyno dynamics, the americans also runs mustangs and hub dynos that seems more calibrated.
Post by driftmonkey on May 30, 2016 9:22:12 GMT
I've stripped his engine for him, blocks been bored for 0.5mm oversized pistons, heads been checked and rebuilt by the machine shop. I've just got to do lots and lots of cleaning, the sump was covered in thick oil and grime. We will be building it in a week and fitting it soon after, once I get my clutch swapped this week.
Interesting about the different dynos over there, all I know is that I want a bit more than I had last time.
Post by atlex on Jul 18, 2016 19:28:39 GMT
So.... Skuzzle mapped my car today. 181 hp at the wheels with 13psi of boost. safe timing on a mix of old Shell SUL (98?) and fresh BP SUL (97). standard 1.6 with G19 kit, td04-13t, yellow rx8 injectors, stage2 exedy paddle and lightened fly.. and the all-important me221 ecu. initial response to my first drive was 'it is canoeing terrifying' but I'm growing to like it now. The pick-up now feels like a lorry just ran into the back of me.
Post by josho on Jul 19, 2016 10:40:47 GMT
So.... Skuzzle mapped my car today. 181 hp at the wheels with 13psi of boost. safe timing on a mix of old Shell SUL (98?) and fresh BP SUL (97). standard 1.6 with G19 kit, td04-13t, yellow rx8 injectors, stage2 exedy paddle and lightened fly.. and the all-important me221 ecu. initial response to my first drive was 'it is canoeing terrifying' but I'm growing to like it now. The pick-up now feels like a lorry just ran into the back of me. I would like a passenger ride pls
Post by atlex on Jul 19, 2016 11:20:43 GMT
I would like a passenger ride pls You can be has.
Post by josho on Jul 19, 2016 11:45:56 GMT
I would like a passenger ride pls You can be has. Ermagerd
Post by wannabe on Jul 19, 2016 13:46:39 GMT
initial response to my first drive was 'it is canoeing terrifying' but I'm growing to like it now. The pick-up now feels like a lorry just ran into the back of me. Now, see, I want to experience this... but I know that once I'll do, I'll want to start going silly with mine, and it's already bankrupting me just getting it back to a reasonable condition...
