Post by Zed. on Sept 3, 2018 13:04:46 GMT
drove it, had a few 'unexpected' sideways moments out of junctions & a Bollocking from my Mrs in exchange Rich.
Post by FFS Corders on Sept 3, 2018 19:46:24 GMT
Went to JAE for the weekend
Aand now it won't idle
Post by Zed. on Oct 11, 2018 14:26:20 GMT
fitted new tyres (rainsport3) & noticed the old tyres were badly worn on the inside... time to re-set the tracking....... so, arranged to use a friends ramp & lazer-alignment stuff for a few hours oneday nextweek also noticed a cam oilseal is leaking so another job on the list Rich.
Post by sheppie on Nov 29, 2018 16:39:32 GMT
Discovered rot on rear quarter sills
Post by Zed. on Nov 29, 2018 17:55:55 GMT
as the car is now relaxing for the winter (off the road) I decided to start the engine & let it idle with the heater running to dry the interior as its somewhat moist in this part of Wales nothing else to report.... Rich.
Post by smighall on Nov 29, 2018 19:27:35 GMT
Completed the wiring for mk2.5 headlight conversion, finished spraying new bumper (jury is out on the quality of it, not expecting much from rattle cans). Swapped the slim D1 quick release for a normal size one to space the wheel closer to me.
Next up get the bumper on then crack on fitting the turbo kit.
Post by FFS Corders on Nov 29, 2018 19:46:12 GMT
At the end of the drive in front of a rather wobbly fence panel...nice rest up til new year
Post by dadbif on Nov 29, 2018 22:13:40 GMT
Increased my idle VE in a couple of cells to fix an annoying idle droop..
Post by Zed. on Dec 13, 2018 23:59:34 GMT
as the car is now relaxing for the winter (off the road) I decided to start the engine & let it idle with the heater running to dry the interior as its somewhat moist in this part of Wales nothing else to report.... Rich. Still no change. *End* well, not quite true..... have looked at an industrial garage unit to rent (not suitable for vehicle use) but have another to see shortly that is aproved for vehicle / 'hot' work thats closer...... suppose if I only had the one car & the garage was empty then I'd be able to work at home Rich.
Post by atlex on Dec 14, 2018 1:02:53 GMT
Finished a special rear heatshield to keep heat out of the boot on the trubro car. I've taken a standard heat shield and added heat-reflective matt to it, with high temp epoxy.
Post by Zed. on Jan 2, 2019 12:29:26 GMT
lastnight I removed the seats to try & dry them... theres puddles in the footwells & carpets F'Kin thing..... Ebay Mercedes M45 Supercharger has landed....... now the fun of mount-bracket design & manufacture then the 'extra' costs of ecu etc. replacement will it run or drive again? Rich.
Post by Whistler on Jan 2, 2019 15:22:01 GMT
Started to cut the rear screen bond from hardtop with a smashed window. #Ballache
Post by smighall on Jan 2, 2019 15:38:45 GMT
Drove it for the first time with the TD04 on, and it didn't blow up!
Post by FFS Corders on Jan 2, 2019 16:24:04 GMT
Removed mouldy steering wheel and cleaned it
Then took out the radio, surround, dash insert and also the Speedo
Then began removing the perspex from the Speedo cover...onot a few cracks so far
Post by JamesMk3 on Jan 2, 2019 16:40:01 GMT
Try leaking now! May have gone a little OTT w/ the sealant though....
