Post by dadbif on Apr 12, 2022 6:29:05 GMT
You’re in the land of the free, a few stars ‘n stripes and a baseball cap on backwards ….
Post by atlex on Apr 12, 2022 9:16:37 GMT
Just be glad it ran I'm trying to remember, was this a recently rebuilt engine ? And are you running a controlled boost or is it wastegate ? I had a log manifold before getting a CFD'd cast one from the same company (G19) and it went from 160@wheels to 220@wheels based on just that change and a tune. Given you're stateside I think the ideal combo there is the FM mani and T25somethingsomehting, or if you are forged, a borgwarner. And obviously pull the injectors and get them cleaned and tested, or, just replaced..
Post by niklas on Apr 12, 2022 10:43:24 GMT
Gtx-posse checking in.
The borgs are nice, but the gtx's are too.
There is a whole lot of fanboying around the borgs.
Post by zoona on Apr 12, 2022 10:44:33 GMT
Annoying. On the other hand geting something better than the yellows is a good thing. And you probably have a much better, smoother map now? If so its easy just adding boost later on. yes. new injectors on the way. and is definitely feelign a lot better than before. He said that becase of of injectors not being matched very well, he was having to add more fuel than he normally woudl to make sure one of them didn;t lean out too much. so new injectors, and a quick visit back and that should be better. Add stickers. Proven route to WHP gains. 😊 You’re in the land of the free, a few stars ‘n stripes and a baseball cap on backwards …. You reminded me of this review, and it never fils to make me smile. Just be glad it ran I'm trying to remember, was this a recently rebuilt engine ? And are you running a controlled boost or is it wastegate ? I had a log manifold before getting a CFD'd cast one from the same company (G19) and it went from 160@wheels to 220@wheels based on just that change and a tune. Given you're stateside I think the ideal combo there is the FM mani and T25somethingsomehting, or if you are forged, a borgwarner. And obviously pull the injectors and get them cleaned and tested, or, just replaced.. i am... and the noise has gone, so pretty safe bet it was the lifters - yes... i know... you all told me that's what it was... Recntly as in 4 years ago, but on just run. Yes, it has boost controlled. i was looking at the g19 ones as i have heard good things about them, but i guess i should look at something here as well. I did have an appointment at the DMV to get it registered, but only realised late last night that it has to be insured first. Moved the appointment to this afternoon, so i can investigate... Likely to be hideous. so it may stay unregistered for a bit longer. On the plus side, my wife suggested that I look at entering the SPEC miata series here becuase there aren't (m)any UK style track days around. I did tell her how much that might cost... but she still suggested it. woop!
Post by zoona on Apr 12, 2022 10:46:57 GMT
And, it probably doesn't need saying, but thanks to everybody who answered my panicked posts as i tried to get this thing up and running. I think i would have thrown the towel in a long time ago if not.
Post by zoona on Apr 12, 2022 11:05:15 GMT
Gtx-posse checking in. The borgs are nice, but the gtx's are too. There is a whole lot of fanboying around the borgs. I can feel a big meeting with the financial controller coming on...
Post by scottydugg on Apr 12, 2022 11:11:23 GMT
It survived the dyno and injectors are an easy swap, win win! Hopefully you get it registered and can drive it to the dyno next time!
Post by zoona on Apr 12, 2022 12:54:58 GMT
i think i need some manifold and turbo help... time to do some forum searching with my "billy bullprarrie canoeter' filter on.
Post by niklas on Apr 12, 2022 17:20:46 GMT
Easy - get a larger mitsu turbo, mani to suit
Less easy - be prepared to reweld the hotparts and such. Get any turbo you fancy. The borgs or a gtx2860r gen2 comes to mind.
But then again, much power explodes new and exciting parts of the car.
Set your power goal and build around that. A forged engine will take what you throw at it. The trans will not.
I figure that a ~220whp 5 is the most playful kind. And its quick.
250-260 is starting to get fast
334whp is scary at first, and is the most I've tried. I don't really feel the need for more and last year I ran low boost (260whp) on most b-roads due to that being easier to drive spiritedly since it demands less throttle...eh..planning. But then, I regularily run high boost for the insanity of it.
Post by zoona on Apr 12, 2022 23:05:15 GMT
Easy - get a larger mitsu turbo, mani to suit Less easy - be prepared to reweld the hotparts and such. Get any turbo you fancy. The borgs or a gtx2860r gen2 comes to mind. But then again, much power explodes new and exciting parts of the car. Set your power goal and build around that. A forged engine will take what you throw at it. The trans will not. I figure that a ~220whp 5 is the most playful kind. And its quick. 250-260 is starting to get fast 334whp is scary at first, and is the most I've tried. I don't really feel the need for more and last year I ran low boost (260whp) on most b-roads due to that being easier to drive spiritedly since it demands less throttle...eh..planning. But then, I regularily run high boost for the insanity of it. 220-230 is my ideal target, which i thought should be doable on my setup... i still haven't looked at the gaskets and studs yet - we have started some building work, so been busy sorting that out. Perhaps they are loose and that will find another 30 hp... I was about to get it registered, and then realised it needs to be insured first. Phoned my broker, and it turns out that nobody will insure me on a foreign licence. So i need to pass that test first... which is coming up soon. The upside is that it is only going to cost me $490 for the year, instead of $800 for six months for the mini... I don't understand this place.
Post by dadbif on Apr 13, 2022 6:48:34 GMT
Fingers crossed you pass your test. 🤞
Post by niklas on Apr 20, 2022 17:06:07 GMT
I hope that you'll get another car for spec miata. This one will cease to be pristine fast if entered.
Post by zoona on Apr 20, 2022 18:45:14 GMT
I hope that you'll get another car for spec miata. This one will cease to be pristine fast if entered. I'm not sure my wife realised what she was suggesting... Tune may change when numbers are discussed. But, yes - it would be a different car...
Post by zoona on Apr 21, 2022 18:17:35 GMT
I PASSED!
Thank fuck for that.
Post by Zed. on Apr 22, 2022 9:47:58 GMT
Passed OUT? Passed Muster? Passed the Dutchie (on the left hand side)? passed driving test? Rich.
