Post by Horney on Mar 10, 2016 22:03:55 GMT
One bonnet collected.
Post by Horney on Mar 10, 2016 23:27:03 GMT
Post by Horney on Mar 10, 2016 23:28:02 GMT
It was a tight fit but it's in.
Post by 5alive on Mar 11, 2016 0:08:04 GMT
A snug fit.Good luck getting it out again
Post by rhyswh on Mar 11, 2016 15:48:29 GMT
Thanks guys! Really appreciate it.
Post by rhyswh on Mar 17, 2016 15:16:08 GMT
Took the bumper off last night to have a look and I'm not sure if I can fix it. The cross-member (the thing the radiator attaches to) is bent and where the sidelight sits has been completely crushed! Is the cross-member (if that's what it's called) something that bolts in? Good side Bad side The cross-member looks worse in real life! What do you guys think?
Post by Horney on Mar 17, 2016 15:26:57 GMT
I'm pretty sure it bolts onto the end of the chassis rails. Certainly looks like it form the pics.
Post by rhyswh on Mar 17, 2016 16:18:54 GMT
From what I could make out it looks part of the chassis rails.
Post by Horney on Mar 17, 2016 16:23:16 GMT
I think you might be right. I don't think that bit does much though. Maybe mounts for the side light/indicator unit? Get that wing and headlight unit off and you'll have a better understanding of what you've got to deal with. I have to be honest, if it was me I'd hack that end off with a grinder, slap on all the new panels and forget about it. I'm a bit cowboy sometimes though.
Post by rhyswh on Mar 17, 2016 16:27:16 GMT
Well that is what I'm considering lol
Post by rhyswh on Mar 17, 2016 16:55:24 GMT
I think the sidelights actually attach to the bumper so that shouldn't be a problem. Biggest issue I might have is I think the wing is attached to something that's now been crushed!
Post by Reechard on Mar 17, 2016 17:24:24 GMT
Id cowboy it as well myself and hack it off. But as Nick says get the wing and bits off so you can have a proper look at it and go from there
Post by rhyswh on Mar 17, 2016 18:31:16 GMT
Huge thanks to boringgit, got the sidelights, headlight casing and lid in the post yesterday.
Will take the wing off this weekend and have a proper look.
Post by 5alive on Mar 18, 2016 0:02:20 GMT
The leg looks straight,square and ok from the pic`s,if it were me,i would try to pull it out as best as poss,cut off the worst bits like Horney said. Find one at a breakers,cut a repair panel more from the car in the breakers and trim it back so it fits perfectly,then weld the part back together. It`s all hidden behind the outer panels anyway,so a bit of paint once it`s all back together and job done. Don`t give up,anything can be fixed Have a look here for inspiration, www.mx5cartalk.com/forum/viewtopic.php?f=57&t=45260you will learn more about how it went together in the first place and have the satisfaction you repaired it yourself. Very best of luck to you.
Post by rhyswh on Mar 18, 2016 9:05:54 GMT
That link is very helpful and from what I can make out the crossmember is welded on. How much does a cheap welding kit cost? This could be my way of learning how to weld! I have no knowledge at all when it comes to welding but I think the cheapest option is MIG?
Edit: Just remembered my garage is limited to 13amps, does this mean I wouldn't be able to use a welder in the garage?
