Post by rich5660 on Nov 20, 2017 13:20:16 GMT
oli
Post by oli on Nov 26, 2017 20:46:39 GMT
VF35 is a good turbo. Had one for about 6 months in my wardrobe, not fitted it yet haha waiting to drop some forged rods in over winter. I thought they were pretty easy to get hold of haha the VF34 however is a little harder and a fair bit more expensive but are ball bearing turbos so probably better for the bigger power builds.
Post by rich5660 on Nov 27, 2017 12:26:15 GMT
the only difference is the exhaust housing (P18 vs P15) so the 34 will make more power at the expense of spooling time. I think the 35 is rated for over 300whp so it was good enough for me. obviously on a 2.5 litre Scooby its not much of a difference but on a 1.8 mx5 I expect it would be noticeable? I think the 35 is only rarer because it only came on the type RA??
what injectors are you looking to run? if you aren't going for silly numbers (240whp or less) then let me know and ill sell you my yellows and ill move up to some high cc denso's
failing that sell me your 35 so I have a spare!
oli
Post by oli on Nov 27, 2017 14:56:08 GMT
I've got yellows in there already for my td04. But got a set of DW 700ccs to go in with the new turbo.
Post by rich5660 on Nov 29, 2017 13:02:34 GMT
have you looked into new plugs and leads? if im going to turn the boost up again (its inevitable) then ill be looking at some super sparky spark plugs and some fatter leads
oli
Post by oli on Nov 30, 2017 21:03:04 GMT
I've made some COPS with some toyota units from eBay. Less than £50 So far for everything, but need to make or buy a bracket to secure them with.
Post by rich5660 on Dec 6, 2017 12:25:49 GMT
