Post by atlex on May 18, 2016 22:51:48 GMT
I've done every car I've owned never gets any easier, the noise is terrifying. Yep, even the 2CV. Twice. Have to ask.. what did the 2CV make ?
Post by myothercarsa2cv on May 18, 2016 22:57:22 GMT
If I remember correctly... 28.1bhp on the first run, 30.8bhp on the second after fitting higher compression pistons. Actually made a big difference on the road. I'm contemplating dropping in a big bore engine with hot cam for about 45bhp, that should fly. P.s. Big bore is like 670cc
Post by djdave25 on May 19, 2016 6:17:18 GMT
Can you put me down for a slot if your not already full
Post by cybot on May 19, 2016 7:22:49 GMT
If I remember correctly... 28.1bhp on the first run, 30.8bhp on the second after fitting higher compression pistons. Actually made a big difference on the road. I'm contemplating dropping in a big bore engine with hot cam for about 45bhp, that should fly. P.s. Big bore is like 670cc Not as bigger a bore as you'll find on Blatchat these days
Post by Horney on May 19, 2016 7:40:06 GMT
Can you put me down for a slot if your not already full Done.
Post by myothercarsa2cv on May 19, 2016 7:44:53 GMT
If I remember correctly... 28.1bhp on the first run, 30.8bhp on the second after fitting higher compression pistons. Actually made a big difference on the road. I'm contemplating dropping in a big bore engine with hot cam for about 45bhp, that should fly. P.s. Big bore is like 670cc Not as bigger a bore as you'll find on Blatchat these days Ha! As boring as it may be, getting the DRE bulk buy on there might boost the numbers considerably... There were about 40 takers last time...
Post by cybot on May 19, 2016 8:36:16 GMT
Not as bigger a bore as you'll find on Blatchat these days Ha! As boring as it may be, getting the DRE bulk buy on there might boost the numbers considerably... There were about 40 takers last time... Good point.
Post by rich5660 on May 19, 2016 8:46:10 GMT
I'll be there however I don't quite fancy running the car on the dyno... I'm not 100% sure I trust it not to blow up haha!! ? x Even if it did blow up you'll have broken it in Skuzzle's garage, just get them to fix it or don their tools and fix it yourself (or attempt to anyway). Fingers crossed mine is on the ME ECU by then
elly
Post by elly on May 19, 2016 12:53:10 GMT
I'll be there however I don't quite fancy running the car on the dyno... I'm not 100% sure I trust it not to blow up haha!! ? x I'm putting a rotary on the dyno haha you have nothing to worry about.
Post by rich5660 on May 19, 2016 18:01:24 GMT
I won't be on the dyno on Saturday King Horne, spoke to Marc and my car hasn't been worked on since JapDay. I already know it'll be 170.4 at the wheels on wastegate so no point wasting £35. I'll probably still pop up and say hello though
elly
Post by elly on May 20, 2016 6:53:19 GMT
Matt is coming in his scooby now so it can look pretty in the car park.
Post by Horney on May 20, 2016 7:40:08 GMT
Yes! He can take me out for a spin!
elly
Post by elly on May 20, 2016 11:58:53 GMT
Haha It's very quick and it's not even running full boost yet.
Post by boringgit on May 20, 2016 12:56:20 GMT
I might have my head under the bonnet cleaning my oil spills and trying to find out where they are from.. but I'll probably still be there. If anybody want a to help locate my oil spills that would be great.
Post by Horney on May 20, 2016 13:02:43 GMT
I might have my head under the bonnet cleaning my oil spills and trying to find out where they are from.. but I'll probably still be there. If anybody want a to help locate my oil spills that would be great. skuzzle has a tool for that, I think it's called a Marc.
