jon
Post by jon on Aug 16, 2018 20:16:24 GMT
MX5 parts do (or did at least) one grade colder plugs for FI...
Post by niklas on Aug 16, 2018 20:45:16 GMT
I run Bosch currently, regular over the counter stuff, one step colder than normal. I need to use Bosch since its only them and denso that I've found that have removable tops (I run motorcycle coil on plug that needs this). Before, with normal spark plug leads, I always ran NGK bkr7e gapped to 0.6-7mm depending on boost level. That is one step colder than oem and works fine for a 200-250whp car. You should be able to find them at any old car parts place.
Post by niklas on Aug 16, 2018 20:46:57 GMT
Been searching for some plogs for my supercharger setup to no avail, where did you get yours? 'tis a secret!
Post by dadbif on Aug 16, 2018 21:15:49 GMT
Like the ability to retrospectively edit posts😂
Post by niklas on Aug 17, 2018 9:46:26 GMT
Oh yes, it would be much harder without the ninja edits 😁
Post by niklas on Aug 18, 2018 6:45:57 GMT
And so it begins.
Post by niklas on Aug 18, 2018 17:08:06 GMT
...and it ended with dissappointment. This is the dyno from today. Made on petrol, 95 octane. 0,7 bar of boost and no boost control activated. The ewg setup does hold boost gloriously though. The notch in the curve is where we pulled a couple of degrees of timing. That could use some smoothing. Thats 14 whp more than I came there with. I figured that was a good 95 map. Then the troubles began. First, the car started to run on three cylinders. Compression was good though and it was only a fouled plug. Quick fix since I had brought another set. After that we where going to set it up on e85 and start making some real power. Sadly, there was no good way of draining the tank completely, it was still half full of 95. Disconnecting the fuel hose is a bit tricky on my car. I have a convenient, although slightly crowded connection, but using that without an extension would have drenched the dyno in petrol. We did not want that. So we drained it with a hose through the filler. We couldnt drain it completely though, some 5-8L remained. After filling it up with e85 it was still only e59. So we had to call it quits for me to return another day. When that is going to be remains to be seen. I need to run through a couple of tanks of good quality e85 and find room in my rather compact work schedule. The tuner is only availiable weekends, and I'm often on call on those. Well well. All in all, I learned that if tuning for dual fuels, do it in two different sessions, preferably some time apart. To tune on e59 would have been hell to get safe and right with the interpolation between the 95 and e85 maps, it would also have netted me less power. At least it did not explode.
Post by niklas on Aug 27, 2018 19:16:10 GMT
I realized I didn't specify that the above dyno is on the wheels. That said, the chassis is fast, the engine is slow. At least I'm already used to it, and its less than before, although with a nice area under the curve. I need to dial in boost control and work on the cold starts etc before the later part of september when I'm back to the dyno, but the heatwave has changed into rain storms. The car is not very good in rain anymore, a slight bit stiff.
Post by howardb66 on Aug 28, 2018 18:21:40 GMT
226 ATW Iisn’t exactly shabby though. I’m nowhere near that & seem to really piss off a lot of supposed quick cars in the speed championships that I compete in...... I can keep up with my friends Countach easily at & he loves that!! Considering I paid 1/200 of what his car is worth..... BTW are you sure that’s you’re 6 secs to 62(100)? I’m 5.6 secs on the datalogger with much less HP & grip, but it’s 60-120 mph where the MX5 seems to really take off.
Post by niklas on Aug 28, 2018 19:37:37 GMT
Heh, it was kind of a guess with 6s. Its a 6-speed with 3.636 rear, but that shift to third delays things. I just pulled a number out of the blue, my best on a regular non-prepped surface with the old engine and 252whp was something like 4.8s The old engine is also the reason that I'm moderately impressed with my current power. But don't get me wrong, 200-220whp in an mx5 feels like what the car should have had from the factory always liked that amount of power in a 5, thats why I put it there for the 95 map
Post by howardb66 on Aug 29, 2018 10:33:17 GMT
Interesting what you say about the 2nd - 3rd gear change. I was contemplating a 6 speed box but because of the short 2nd gear with my 4.1 diff, I didn’t think it was worth it, especially on hill climbs that aren’t that fast & being able to hang onto 2nd can help to not change gear sometimes works better with the slightly longer ratio of 2nd in the 5 speed.
Post by niklas on Aug 29, 2018 11:30:12 GMT
If the 5 speed would handle it, one of those with a 3,6 rear would have been nice. I rarely use 2nd on track nowadays, but sometimes find myself wanting to. For autocross second is often the main gear for me, but Im occationally bouncing off the limiter since a change up would loose time.
Post by niklas on Sept 3, 2018 20:34:25 GMT
Just been out a few hours tuning closed loop boost control. I learned that its stupid to take shortcuts. I just used the initial bias table from my last setup, big mistake. I've been checking how well overboost works something like a hundred times, not getting it to be consistent on transient throttle and high revs. I will be tuning open loop all over again to get those values in the initial duty tables.
note to self, there is no shortcuts in ms3 boost control.
Post by niklas on Sept 4, 2018 19:24:04 GMT
Fixing the bias tables was the thing. Running in closed with kind of good boost. Varies something like 5kpa. Target boost on e85 is 210kpa now. With 170kpa it was a bit meh. That was 220whp. With a better fuel map and 210kpa now, its a load of fun. And i still have a bit of boost left to go when I get to the dyno. Everything about it is starting to feel great The daily e91 320d developed a boost leak though. Changed all the o-rings on the boost pipes without any luck. Anyone know where they (n47) generally cracks their vacuum pipes?
Post by howardb66 on Sept 4, 2018 21:32:27 GMT
If you can find out any info on the Alpina D3 MT that might help. They run a 330d intercooler with hard Aluminium pipes- just an idea....
