Just found the results of a pretty large winter tyre test - thought it might be useful, especially as it was done on 195/65/15 tyres, rather than these 30-profile 19s that even Fiestas seem to be running noawadays!
All 51 tyres - all Wet Braking tested, the top 30 also being Snow Braking tested:
www.tyrereviews.co.uk/Article/2018-51-Winter-Tyre-Shootout.htmThe top 20 that went on to a full Auto Bild test:
www.tyrereviews.co.uk/Article/2018-Auto-Bild-Winter-Tyre-Test.htmThe graphs are quite interesting!
Results turned out as follows (copied here because I never trust things not to disappear...). Personally I'm not quite sure why the 2nd place tyre isn't 1st - it seems that 'noise' and 'wear rate' and 'price' have swayed the scoring, whereas personally I would rather pay out for a tyre that is the best in how it performs, which seems to be the WinterContact TS 860!
1st: Dunlop Winter Sport 5Total: 49 / Dry: 6 / Wet: 7 / Snow: 7 / Comfort: 7 / Rolling Resistance: 7 / Noise: 7 / Wear: 8
Positive: The best tyre on test, with no drawbacks. Stable handling in all conditions, precise steering behavior and good feedback.
Negative: None mentioned.
2nd: Continental WinterContact TS 860Total: 50 / Dry: 6 / Wet: 8 / Snow: 7 / Comfort: 9 / Rolling Resistance: 7 / Noise: 7 / Wear: 6
Positive: Excellent all rounder with excellent winter performance. High steering precision and dynamic handling on snow and in the wet, good comfort, low rolling resistance.
3rd: Kleber Krisalp HP3Total: 46 / Dry: 6 / Wet: 6 / Snow: 9 / Comfort: 5 / Rolling Resistance: 7 / Noise: 8 / Wear: 5
Positive: Inexpensive winter tyre with excellent snow performance. Short braking distances in all conditions, low noise, good price to performance ratio.
4th: Fulda Kristall Control HP2Total: 43 / Dry: 5 / Wet: 7 / Snow: 7 / Comfort: 5 / Rolling Resistance: 7 / Noise: 7 / Wear: 5
Positive: Winter specialist with a balanced performance in the dry and wet. High aquaplaning safety, quiet, low fuel use.
5th: Hankook Winter i cept RS2Total: 45 / Dry: 6 / Wet: 7 / Snow: 8 / Comfort: 6 / Rolling Resistance: 4 / Noise: 5 / Wear: 9
Positive: Premium tyres with excellent handling qualities in all weather conditions. Low wear, good price / performance ratio.
Negative: Slightly high rolling resistance.
6th: Goodyear UltraGrip 9Total: 48 / Dry: 5 / Wet: 7 / Snow: 9 / Comfort: 6 / Rolling Resistance: 8 / Noise: 6 / Wear: 7
Positive: Good steering precision on snow covered and wet roads, safe aquaplaning properties, high mileage, low rolling resistance.
Negative: Extended dry braking distances.
7th: Debica Frigo HP2Total: 39 / Dry: 6 / Wet: 5 / Snow: 6 / Comfort: 5 / Rolling Resistance: 6 / Noise: 6 / Wear: 5
Positive: Good value winter tyres with balance driving on snow and dry roads. Short braking distances in all weather conditions.
Negative: Average handling in the wet.
8th: Falken Eurowinter HS01Total: 40 / Dry: 6 / Wet: 6 / Snow: 5 / Comfort: 7 / Rolling Resistance: 4 / Noise: 7 / Wear: 5
Positive: Balanced winter tyres with a good ability on on snow and dry roads. Best aquaplaning performance.
Negative: Average wet cornering.
9th: Nokian WR D4Total: 46 / Dry: 5 / Wet: 4 / Snow: 9 / Comfort: 5 / Rolling Resistance: 10 / Noise: 7 / Wear: 6
Positive: Best tyre for snow covered roads, good price / performance ratio with low rolling resistance.
Negative: Average wet performance.
10th: Uniroyal MS+ 77Total: 40 / Dry: 4 / Wet: 7 / Snow: 7 / Comfort: 7 / Rolling Resistance: 5 / Noise: 5 / Wear: 5
Positive: Excellent in the wet, good aquaplaning resistance, comfortable, well priced.
Negative: Long dry braking and poor dry handling.
11th: Michelin Alpin 5Total: 37 / Dry: 6 / Wet: 6 / Snow: 4 / Comfort: 2 / Rolling Resistance: 4 / Noise: 5 / Wear: 10
Positive: Even as one of the most expensive tyres on test it finished as the best value tyre due to extremely low wear. Good in the wet and dry.
Negative: Average snow performance, high rolling resistance.
12th: Semperit Master Grip 2Total: 43 / Dry: 4 / Wet: 6 / Snow: 7 / Comfort: 6 / Rolling Resistance: 6 / Noise: 8 / Wear: 6
Positive: Good in the snow and wet, low noise.
Negative: Long dry braking, average dry handling.
13th: Pirelli Cinturato WinterTotal: 42 / Dry: 5 / Wet: 7 / Snow: 8 / Comfort: 7 / Rolling Resistance: 5 / Noise: 8 / Wear: 2
Positive: Dynamic sporty handling in the snow and wet, good steering precision.
Negative: Poor wear, low value, average dry grip.
14th: Bridgestone Blizzak LM001 EVOTotal: 45 / Dry: 5 / Wet: 7 / Snow: 4 / Comfort: 9 / Rolling Resistance: 7 / Noise: 8 / Wear: 5
Positive: Wet specialist with short braking distances and good aquaplaning properties, good value.
Negative: Poor snow performance.
15th: Yokohama BluEarth Winter V905Total: 43 / Dry: 7 / Wet: 6 / Snow: 4 / Comfort: 8 / Rolling Resistance: 6 / Noise: 7 / Wear: 5
Positive: Dry specialist with short braking distances and good handling in the dry. Good comfort.
Negative: Average snow performance.
16th: Barum Polaris 3Total: 36 / Dry: 5 / Wet: 4 / Snow: 7 / Comfort: 4 / Rolling Resistance: 7 / Noise: 5 / Wear: 4
Positive: Good snow performance, short wet braking distances, low price.
Negative: Understeer in the wet, long dry braking, poor wear.
17th: Vredestein Snowtrac 5Total: 35 / Dry: 6 / Wet: 4 / Snow: 6 / Comfort: 5 / Rolling Resistance: 6 / Noise: 5 / Wear: 3
Positive: Balance performance in the snow and dry, low rolling resistance.
Negative: Low grip in the wet, poor wear.
18th: Matador MP 92 Sibir SnowTotal: 37 / Dry: 5 / Wet: 4 / Snow: 5 / Comfort: 7 / Rolling Resistance: 6 / Noise: 7 / Wear: 3
Positive: Good snow handling, good comfort, low priced.
Negative: Poor wet performance, long dry braking, high wear.
19th: Firestone Winterhawk 3Total: 36 / Dry: 5 / Wet: 4 / Snow: 5 / Comfort: 4 / Rolling Resistance: 6 / Noise: 6 / Wear: 6
Positive: Low price, ok in snow.
Negative: Low grip and slow steering in the wet, long wet and dry braking, low comfort.
20th: Gislaved Euro Frost 6Total: 37 / Dry: 5 / Wet: 4 / Snow: 6 / Comfort: 6 / Rolling Resistance: 6 / Noise: 6 / Wear: 4
Positive: Balanced snow performance.
Negative: Poor wet grip, slow wet steering, low aquaplaning resistance, long dry braking distances.
