Post by wannabe on May 19, 2016 15:50:57 GMT
tsp
Post by tsp on May 19, 2016 17:27:14 GMT
I looked at it. Again. Then walked off. Again
Post by FFS Corders on May 19, 2016 17:57:36 GMT
Heard a clonking noise from the suspension
Raised the car up, couldnt see anything untoward
Set the damping to 12 from full hard on the front...not clonking much on the first drive
Post by joeytalent on May 19, 2016 23:04:02 GMT
Changed my timing belt and put the HKS cams in. Battery ran out on the laptop before I could do the timing, but super chuffed with what I got done in a post-work spanner session.
Post by joeytalent on May 20, 2016 16:07:06 GMT
Got a scare. Went back to the garage this morning to set the timing. Massive clunking noise from engine. prarrie canoe myself.
Turns out I hadn't tightened the bolts up on the water pump pulley.
Post by myothercarsa2cv on May 20, 2016 16:14:36 GMT
Got a patch welded on for the MOT tomorrow. Wish me luck...
Post by FFS Corders on May 20, 2016 16:30:39 GMT
changed the slave cylinder on Bambi plus clutch and brake fluid
clutch still not disengaging fully too so going to refurb the master cylinder
then if THAT doesnt solve it, car's basically going nowhere as Megan can't afford a new clutch
Post by joeytalent on May 20, 2016 21:43:02 GMT
Did you bleed it thoroughly? I thought mine was minced, but bled it two or three times and it came back. Seems you have to put a fair amount of fluid through it.
Post by FFS Corders on May 20, 2016 21:50:53 GMT
Bled it about 4 times in the end
It was way better by the last time...but still think there is more wrong than just bleeding
Post by joeytalent on May 20, 2016 21:57:58 GMT
Fair enough, thought it was just worth asking before you do more work! Good luck.
titch
Post by titch on May 20, 2016 22:11:48 GMT
Changed rocker gasket (technically yesterday, meh), fitted my 6 point harness properly, went for a drive, realised oil was still leaking. Looks like it's the cam seals then. Wonderful.
Post by randomfactor on May 20, 2016 22:33:22 GMT
Got a patch welded on for the MOT tomorrow. Wish me luck... Good luck! Any reciprocal mot luck wishing is gratefully received!
Post by boringgit on May 20, 2016 22:50:20 GMT
Changed rocker gasket (technically yesterday, meh), fitted my 6 point harness properly, went for a drive, realised oil was still leaking. Looks like it's the cam seals then. Wonderful. I feel your pain. My car is like a waterfall - made of oil.
Post by Reechard on May 20, 2016 23:45:28 GMT
Opened my post to find my shiny new knob, now just to figure out how to get the old one off. And drove with the roof down in the rain in the dark, not much better feelings than that. I want to bottle that feeling so I remember how much fun the car is if it ever gives me trouble.
Post by rich5660 on May 21, 2016 0:14:42 GMT
Opened my post to find my shiny new knob, now just to figure out how to get the old one off. And drove with the roof down in the rain in the dark, not much better feelings than that. I want to bottle that feeling so I remember how much fun the car is if it ever gives me trouble. It just twists off. Just remember you're replacing it anyway so don't worry about breaking it
