Post by boringgit on Apr 6, 2016 11:53:33 GMT
Went for a drive.
Clem
Post by Clem on Apr 6, 2016 20:32:46 GMT
used it to fetch my broken bike from work
Post by myothercarsa2cv on Apr 6, 2016 23:43:16 GMT
Today I helped a friend replace his turbo oil feed. His original copper hard line had fatigued at the turbo banjo and split, causing quite a leak. This was a total ballache of a job, because everything is in the way. Got there eventually, just need to check it doesn't leak...
phil
I'm new here, be gentle
Post by phil on Apr 7, 2016 14:18:21 GMT
Fitted Green stuff pads all round on the NC and replaced the paper air filter with a K&N one.
Post by pleurotus on Apr 7, 2016 20:01:39 GMT
Took some bits off
Post by Horney on Apr 7, 2016 21:13:19 GMT
Only a few though. lol.
Post by AutotestAddict on Apr 7, 2016 21:32:31 GMT
Tried yet another not-the-proper-way-to-do-it bodge to get my 'charger connected to my throttle body. There are no bolts to fall in this time, and it seems solid. How long will it hold I wonder?
titch
Post by titch on Apr 7, 2016 22:13:59 GMT
Got my head back! Ports fettled, valve seats recut, all rebuilt, 40 thou skim.
Post by Rickster on Apr 8, 2016 14:39:18 GMT
Post by FFS Corders on Apr 8, 2016 14:51:56 GMT
halfway through changing oil and filter
omg taking the filter off is a pain in the rear canoe
Post by boringgit on Apr 8, 2016 15:40:08 GMT
No it isn't. Put on a rubber glove then you can grip it properly. Just wait till you put it back on when it's oily mmmm slippery
Post by Horney on Apr 8, 2016 15:45:02 GMT
Broke down. Well technically it wouldn't start. Weird. Seems to have a flat battery but it was fine yesterday and all I've changed is fitting the Induction kit. Didn't leave anything on but it's flat as a panckake. Today I fixed it. Battery terminal was loose.
Post by zoona on Apr 8, 2016 16:18:43 GMT
got my turbo oil drain flange back after a lot of waiting. Can now put it all back together again now and try out the depowered steering rack.
Just hope i have not broken anything with clocking the turbo slightly to shorten the intercooler piping now the steering pump is gone.
I also have a completely dead battery to contend with.
first things first though. bolt it all back together.
Post by FFS Corders on Apr 8, 2016 16:39:42 GMT
No it isn't. Put on a rubber glove then you can grip it properly. Just wait till you put it back on when it's oily mmmm slippery i did think of this but i decided to get annoyed at it instead all done now first time i;ve used 5w40 so could be fun
Post by FFS Corders on Apr 8, 2016 16:40:36 GMT
Broke down. Well technically it wouldn't start. Weird. Seems to have a flat battery but it was fine yesterday and all I've changed is fitting the Induction kit. Didn't leave anything on but it's flat as a panckake. Today I fixed it. Battery terminal was loose. doh! i've done that a few times also keep leaving tools in the engine bay melted the handles on my dad's snipe nose pliers cos of this
