Post by myothercarsa2cv on May 22, 2017 11:57:31 GMT
Thinking of getting one of these as if I leave the car a while the battery drains (I have a clock and maybe there are other gremlins at play). Anyone fitted one? If so, how?
tsp
Post by tsp on May 22, 2017 12:20:17 GMT
I've been looking into this too. MX5 parts do one but I'd be happier to go with a recommendation
Post by myothercarsa2cv on May 22, 2017 17:43:49 GMT
I've seen those. Certainly would do the job. I was more thinking along the lines of what racers use and accessible from the cabin but I might start with the simple solution!
Post by atlex on May 22, 2017 19:40:50 GMT
Post by rustywheels on May 22, 2017 19:46:45 GMT
Snap! Mine is connected to the negative (I know, rule breaker or what?), and if you do this, you will need an adapter sleeve as the japanese batteries have different sized terminals.
Post by atlex on May 22, 2017 19:52:30 GMT
Most of my batteries are westcos and they fit fine ^ I also use the negative side. it's just simpler and safer imo.
Post by myothercarsa2cv on May 22, 2017 19:55:46 GMT
My westco's negative is under the wing... bit awkward but I'll give it a go!
Post by atlex on May 22, 2017 20:09:18 GMT
So are mine John.... There's space, I promise. Just pull some of the fluff out.
Post by myothercarsa2cv on May 22, 2017 20:20:43 GMT
You must have the hands of a geisha
Post by atlex on May 22, 2017 21:31:54 GMT
fingers of the geisha it's a doddle once you get the hang of it. The discarnect thing is only connected when the bolt is in tight, so you just spin it off a few turns and it's broken the circuit. don't even need to remove the bolt.
Post by myothercarsa2cv on Jun 13, 2017 18:18:38 GMT
I done it. Thanks for the recommendation guys
