Post by wannabe on Apr 10, 2019 15:20:43 GMT
Post by Rickster on Apr 12, 2019 16:25:48 GMT
Took the sparco sprint out and put the standard seat back in so my wife can use it this weekend!😮🤞
Post by Zed. on Apr 12, 2019 17:22:34 GMT
stripped a spare steering-column in preparation for possible eps fiddlin.... now back on the bias-pedalbox fiddlin...... might actually do something usefull Rich.
Post by FFS Corders on Apr 12, 2019 17:54:54 GMT
Started trying to fit passenger rails to my cobra Monaco. Now waiting on delivery of some shorter bolts..
Post by JamesMk3 on Apr 12, 2019 19:15:10 GMT
...Now waiting on delivery of some shorter bolts.. I guess you don't own a grinder? What bolts are you needing. I've got far more sizes than I should ever need!.
Post by FFS Corders on Apr 12, 2019 19:31:08 GMT
No, not yet. That is next month's fun purchase. I bought 10 M8 16mm bolts for like £1.50 (high tensile, obvs. I do actually *care* about my passengers) so I can continue adding to my random fixings collection
Post by martiny on Apr 15, 2019 10:13:23 GMT
Put a 2 ft breaker bar on a rear A arm long bolt, leant a 15 stone man on it and it didn't move.
Eventually it did move a little. An hour later both long bolts were out, intact, due to patience, Plusgas and a mallet. Win. Then in triumph I set about the camber bolts and snapped them. Twats.
Post by Zed. on Apr 15, 2019 11:20:14 GMT
Put a 2 ft breaker bar on a rear A arm long bolt, leant a 15 stone man on it and it didn't move. Eventually it did move a little. An hour later both long bolts were out, intact, due to patience, Plusgas and a mallet. Win. Then in triumph I set about the camber bolts and snapped them. Twats. done exactly that lastyear.... a good excuse to replace the camber-bolts Rich.
Post by wannabe on Apr 15, 2019 12:30:01 GMT
Put a 2 ft breaker bar on a rear A arm long bolt, leant a 15 stone man on it and it didn't move. Eventually it did move a little. An hour later both long bolts were out, intact, due to patience, Plusgas and a mallet. Win. Then in triumph I set about the camber bolts and snapped them. Twats. done exactly that lastyear.... a good excuse to replace the camber-bolts Rich. I need to get my alignment done when I get my steering rack swapped - I may well order some 'just in case'... lol
Crumpets
Insert witty remark here...
Post by Crumpets on Apr 16, 2019 9:03:01 GMT
I need to get my alignment done when I get my steering rack swapped - I may well order some 'just in case'... lol I Highly recommend the skidnation camber bolts - well worth the investment. Very very high quality.
Post by atlex on Apr 16, 2019 9:16:31 GMT
I need to get my alignment done when I get my steering rack swapped - I may well order some 'just in case'... lol I Highly recommend the skidnation camber bolts - well worth the investment. Very very high quality. Seconded these skidnation setup should last another 30 years..
Post by wannabe on Apr 16, 2019 11:21:12 GMT
I Highly recommend the skidnation camber bolts - well worth the investment. Very very high quality. Seconded these skidnation setup should last another 30 years.. Thanks for the feedback, chaps I think I posted before about my reservations, but I guess it boils down to whether the standard (non-locking?) bolts allow some 'slip' in the system, so that if you unexpectedly drop into a bomb crater cunningly disguised as a pothole your alignment goes out-of-whack rather than a wishbone snapping?? If the better bolts transmit more of the sudden impact loads into the wishbones etc. (especially when running polybushes) then I fear something breaking! lol
Post by FFS Corders on Apr 16, 2019 16:17:17 GMT
Personally the lack of anecdotal evidence about people buying the skidnation bolts and that happening is reassuring enough for me
But it would of course be typical that I'd be the first one it happened to should I fit them...
Post by Dweenimus on Apr 16, 2019 17:43:27 GMT
Did a thing. Review to come soon!
Post by wannabe on Apr 16, 2019 22:09:14 GMT
Did a thing. Review to come soon! Was that thing 'block my heating vents so I get cold in winter'?
