Post by teamawesome on Nov 5, 2016 14:02:46 GMT
I have for sale a few items I've made out of MX5 parts. I have 2 of these lamps available. They have been made out of MX5 pistons and rods. One of them I have cleaned up quite a lot and had a bit of a polish over it. The other I've cleaned the carbon off but left the staining for a "used" look. I have used braided flex which gives around 1.5m of cable from the base to the plug. This should be enough for the vast majority! The wiring is only rated to 6 amps so I have replaced the 13 amp fuse with a 3 amp fuse. The lamp is switched on the lamp holder itself and has a safety switch which won't allow the switch to be turned on unless there is a bulb in there. The lamp holder takes a bayonet bulb. Price is per lamp, £95 posted. I also have a candlestick holder. Takes a 35mm candle. I used votive candles in mine.
Post by atlex on Nov 5, 2016 17:47:07 GMT
I really like that. Love reusing car parts. for any reason also.. quite geiger - welded up, etc.
Post by teamawesome on Nov 7, 2016 9:42:39 GMT
Prove you like it, buy it!
Open to offers.
Post by Horney on Nov 7, 2016 10:29:58 GMT
If I didn't have a load of racing to pay for this month I'd be certainly having a lamp.
Post by teamawesome on Nov 7, 2016 22:52:07 GMT
I'll have plenty of other things. I am making cam shaft lamps, a crank shaft lamp and and eccentric shaft lamp. I am making a few clocks too, one from a diff and a couple from a rotary engine.
Post by Horney on Nov 7, 2016 23:31:42 GMT
Ooooh rotary clock sounds cool!
Post by teamawesome on Nov 8, 2016 8:20:53 GMT
Yeah hopefully I won't mess them up!
Post by teamawesome on Jan 5, 2017 19:28:43 GMT
All of the above is sold but I now have 2 of these on offer. One is slightly shorter than the picture as that's how Mazda made them! These are £60.
Post by myothercarsa2cv on Jan 5, 2017 22:21:57 GMT
That's lovely, really nice work. The only way it could get any better is if you had the cam gun drilled, and run the wire down the middle, but I wouldn't know where to get that done... thought of doing a mohair lamp shade?
Post by teamawesome on Jan 6, 2017 10:29:48 GMT
I agree that having the wire completely hidden would be nice, but the cost of having it done (and like you I wouldn't know where to have it done) would most likely make them prohibitively expensive. I have a few more items on the way:
Post by NurseHolliday on Jan 6, 2017 13:36:13 GMT
Holy Canoe how much is that clock?
Post by NurseHolliday on Jan 6, 2017 15:24:52 GMT
Honestly, I want that clock for my mantelpiece. PM me a price.
Post by teamawesome on Jan 6, 2017 15:31:52 GMT
The clocks are £200. A lot of hours go into them. That particular one is sold but I have more on the way.
Post by Vindi (Russell) on Jan 6, 2017 17:40:40 GMT
Very cool, might grab one of those clocks off you when I have the cash
Post by chris71 on Jan 6, 2017 19:58:41 GMT
£200. Taking everything into account,bargain ! Love the rev counter for the clock face. Stunning work Sir.
