Post by atlex on Jan 12, 2017 14:36:56 GMT
just watch.
Post by fizbne on Jan 12, 2017 22:54:24 GMT
Omg yes I wastched something similar the other day it's SOOOOO SATISFYING OMG MELTY MELTY :3
Post by Rickster on Jan 13, 2017 9:42:42 GMT
That last one is just a standard lathe - i assume he just winds it in by hand and uses judgement to stop the chuck at the right time. makes me wonder what you could do with a hi speed power drill and a bottle jack!!!!!! Much skill needed i suspect
Post by atlex on Jan 13, 2017 11:52:43 GMT
powerdrill.. would transfer too much energy back into your hands if hand-held. the friction is massive. imagine producing that much energy by hand.
Post by Rickster on Jan 13, 2017 14:17:39 GMT
powerdrill.. would transfer too much energy back into your hands if hand-held. the friction is massive. imagine producing that much energy by hand. I meant clamped - i wasnt planning on holding it!!!!! I think it would burnout and fall to pieces before you completed a weld though!!
Post by exhausting on Jan 14, 2017 9:31:33 GMT
Tesla battery connections are friction welded. Ultrasonically. It must be a very fast process as you can't get lithium cells too hot. For prospective, Spot welding is the norm, as soldering is too slow.
Post by martiny on Jan 17, 2017 17:49:13 GMT
Tesla battery connections are friction welded. Ultrasonically. It must be a very fast process as you can't get lithium cells too hot. For prospective, Spot welding is the norm, as soldering is too slow. That same process has been used for many years on a microscopic scale to weld fine wires between silicon chips and their external contact pins when maufacturing ICs.
Post by atlex on Mar 29, 2017 20:49:18 GMT
Train burnout, anyone ?
Post by minty on Mar 29, 2017 22:05:40 GMT
I feel for the passengers on the next train D
