Post by Fizbne on Jan 25, 2017 7:59:28 GMT
To build a reliable 1600 that revs to like 8k, you need to do like springs, lifters and all that jazz.
But like. Rly?
I had one of those crystal swapped ECU fandangled things and I regularly went to an indicated 8k+ RPM and the only thing that occurred was great glory and WinRAR.
So like, my question is: Has anyone lunched their engine big time from super loltastic regular visits to 8kRPM?
Thx.
Post by Horney on Jan 25, 2017 9:35:31 GMT
Oil pump is your biggest concern. Regular extended visits to that kind of limit will see it implode.
Post by tropical on Jan 25, 2017 9:58:31 GMT
It would appear that the major bottleneck on these engines is the poor flow of the standard cylinder head. Look at BLiNKs stage 3 results on here or fuzznutz, they have achieved great results on relatively mild cams/low revs. You need the head to be able to flow well and cams that will give good torque higher up in the rev band otherwise the power band is going to drop like a stone after 6500rpm. Also as admin says above the stock oil pump internals will poop themselves pretty quickly.
Post by baconsarnie on Jan 25, 2017 10:23:25 GMT
Is this oil pump destruction as true on the B6 tho? Well documented on BP builds that oil pump is required. But the BP has a worse rod ratio (short sharp inputs from combustion)...
Post by thruxton on Jan 25, 2017 12:18:20 GMT
Hi there. So far this is the best naturally aspirated one I've seen. It's a 1.8 though. This required a vast amount of cylinder head work to fit the oversize camshafts. No point in going to 8000Rpm though if your not benefitting from being there. Rich.
Post by wannabe on Jan 25, 2017 14:24:31 GMT
Nice - I bet it was cheap to get to that much power N/A... lol
Post by thruxton on Jan 25, 2017 14:55:23 GMT
And there lay the problems. That was a believe it or don't believe it ...... £10,000 engine build, boing!
I am genuinely interested though as to why the OP wants to go to 8000Rpm? So if he's reading .....?
Thanks. Rich.
Post by Fizbne on Jan 25, 2017 15:53:51 GMT
And there lay the problems. That was a believe it or don't believe it ...... £10,000 engine build, boing! I am genuinely interested though as to why the OP wants to go to 8000Rpm? So if he's reading .....? Thanks. Rich. Yeah in reading. I'm just in straya. Uh. Well. The only reason is to reliably go: BWAAAAAAAA NYAAAAAAAAAAAAAAAAA BWAAAAAAAAAAAAAAAAAAAAAAA. Without lunching an engine. Would the 1.6 HLA's and general valve train be able to last at sustained limiter bashing?
Post by Fizbne on Jan 25, 2017 15:54:52 GMT
Oil pump is your biggest concern. Regular extended visits to that kind of limit will see it implode. So we're talking the oil pump itself? Hmm. Maybe that's why there was swarf in the head of the old engine. Lol aha.
Post by thruxton on Jan 25, 2017 16:17:35 GMT
To be honest .....
I have no idea what you are saying.
Rich.
Post by Horney on Jan 25, 2017 17:27:17 GMT
Don't worry Rich, you get used to him in the end. Transalation:
Yeah in reading. I'm just in straya. - Yes I am reading the replies although currently I am in Australia so I don't post much during UK hours.
BWAAAAAAAA NYAAAAAAAAAAAAAAAAA BWAAAAAAAAAAAAAAAAAAAAAAA. - I want to have an engine that will reliably rev to 8K because I like the noise and drama.
Without lunching an engine. - Without it breaking something.
Would the 1.6 HLA's and general valve train be able to last at sustained limiter bashing? - This bit is luckily not in Fizbne speech.
Post by thruxton on Jan 25, 2017 17:38:05 GMT
Thank you Horney. Wish I'd never asked now.
Rich.
Post by atlex on Jan 25, 2017 17:50:45 GMT
translator: hired.
Post by Rickster on Jan 25, 2017 19:45:01 GMT
Don't worry Rich, you get used to him in the end. Transalation: Yeah in reading. I'm just in straya. - Yes I am reading the replies although currently I am in Australia so I don't post much during UK hours.
Uh. Well. The only reason is to reliably go: BWAAAAAAAA NYAAAAAAAAAAAAAAAAA BWAAAAAAAAAAAAAAAAAAAAAAA. - I want to have an engine that will reliably rev to 8K because I like the noise and drama.Without lunching an engine. - Without it breaking something.Would the 1.6 HLA's and general valve train be able to last at sustained limiter bashing? - This bit is luckily not in Fizbne speech.You are fluent in Fizbne-ish, did you get a Rosetta cd or was it a night school class!! I'd like to learn but am struggling with English!
Post by robygodzilla on Jan 25, 2017 19:59:28 GMT
Aren't the hlas only good for a max of 7400rpm.
