Post by atlex on Feb 8, 2017 19:51:27 GMT
One of my cars has a fuel pump cut-off switch, which is nice as a way to give the engine a few seconds of cranking to get oil going.
My other mk1 doesn't, wondering what the easiest way to do that is tho.
Pull the cas ? pull a fuse or relay ?
Post by joeytalent on Feb 8, 2017 20:39:23 GMT
You could pull the fuel pump relay, it's in the fuse box in the bonnet.
Post by Rickster on Feb 8, 2017 21:55:00 GMT
My Eunos fuel pump relay is above right knee next to steering column
Post by joeytalent on Feb 8, 2017 23:30:45 GMT
My bad, I meant the fuel injector relay in the fuse box in the bonnet
Post by atlex on Feb 9, 2017 16:53:26 GMT
pulling the injector fuse/relay in the fuse box definitely did the trick.
