Post by stoney on Mar 2, 2017 9:46:54 GMT
Hello, Just from a point of view that I don't really care too much about emissions and don't want exhaust gases going back into my engine, have any of you done EGR delete's in the past and is it a pain to do or is it relatively easy? Car is a 2004 Euphonic 1.6. It sounds like it has variable timing as around 5k it really picks up and there's a difference in the sound. Any advice/info is greatly appreciated Gracias Will
Post by Horney on Mar 2, 2017 9:58:40 GMT
Pretty sure the 1.6s never came with VVT.
You should just be able to blank off the EGR with no issues.
Post by stoney on Mar 2, 2017 10:07:57 GMT
Oh also what are people's opinions on 'engine cleaning' because when changing my spark plugs yesterday and looking into the cylinder the pistons were super carbony and black and didn't look full of performance.
Just trying to get as much out of the engine as cheaply as possible.
Post by stoney on Mar 2, 2017 10:31:01 GMT
Pretty sure the 1.6s never came with VVT. You should just be able to blank off the EGR with no issues. Yeah that's what I thought, maybe it's just how mx5 engines rev. & cheers I might try doing it myself then
Post by atlex on Mar 2, 2017 10:55:32 GMT
no VVT on 1.6 as horny said
5K ? might be a vibrating heat shield....
Post by atlex on Mar 2, 2017 11:05:38 GMT
re cleaning - you could look at decarbonizing your engine.. it requires a little water and maybe a little hose in the intake to let the water in. there's some youtube vids on that.
requires a hot engine tho!
Post by stoney on Mar 2, 2017 11:22:53 GMT
no VVT on 1.6 as horny said 5K ? might be a vibrating heat shield.... As in the exhaust note changes at 5k and the car really picks up
Post by atlex on Mar 2, 2017 11:24:05 GMT
no VVT on 1.6 as horny said 5K ? might be a vibrating heat shield.... As in the exhaust note changes at 5k and the car really picks up maybe that's just advanced straight-four atmocharging at work.
Post by stoney on Mar 2, 2017 11:27:02 GMT
As in the exhaust note changes at 5k and the car really picks up maybe that's just advanced straight-four atmocharging at work. Yeah whatever that is hahah but it feels similar to VVT. I just don't know much about mx5 engines
