Post by AutotestAddict on Apr 23, 2017 15:14:11 GMT
Have been ridiculed many times for the daft mini wheels on my '5, but I maintain that the bum dyno says it is faster* with the teensy wheels.
Engineering explained has got my back -
*better acceleration when you have traction, I concede there is less grip and its probably slower (although likely fun-er) out of corners.
Post by atlex on Apr 23, 2017 17:26:29 GMT
+1 definitely win to increase diff FD if you aren't trubroing.
Post by Horney on Apr 23, 2017 17:29:45 GMT
Yeah I'll be fitting a 5 speed TorSen to my 6 speed mk3 track car eventually.
Post by sandys on Apr 23, 2017 17:43:58 GMT
6spd with the 4.1 from the 5 speed diff is probably the route I should have taken as that will have a great effect on the gearing, but I prefer the 5spd box so went the other way, mine feels pretty good though having gone from 4.1-4.44, probably should of fitted 4.6 but was concerned about going too short so took the compromise but driving with the 4.44 I realize I could of took it more aggressive.
Post by Horney on Apr 23, 2017 18:46:47 GMT
I'm going to fit a lightened flywheel as well. 1st and 2nd should be pretty ballistic with that combo.
rikk
Post by rikk on Apr 23, 2017 23:02:30 GMT
Not had mine long but I always find myself pretty impressed with how it goes in the 1st-3rd. 4.3 diff + factory lightened flywheel. Basically I am the limitation, a problem I am hoping more miles will solve...
Post by minty on Apr 24, 2017 6:52:20 GMT
Not had mine long but I always find myself pretty impressed with how it goes in the 1st-3rd. 4.3 diff + factory lightened flywheel. Basically I am the limitation, a problem I am hoping more miles will solve... Rikk, if you get the chance at some point could you let me know what rpm you are seeing in 5th at a GPS indicated 70mph?? Cheers
Post by atlex on Apr 24, 2017 9:33:39 GMT
Post by minty on Apr 24, 2017 21:07:02 GMT
Cheers Atlex, that's what I was looking for
Post by atlex on Apr 24, 2017 21:35:57 GMT
^ np minty weirdest thing is that those ratios show that the 6 speed actually has shorter legs than the 5 speed, in the top gear.
rikk
Post by rikk on Apr 25, 2017 8:55:37 GMT
Nice! Kinda supports my experience that 70 is 'just under 4k'
Post by howardb66 on Apr 25, 2017 10:16:38 GMT
Last year I ran a 4.7LSD on the NA with itbs, really helped out the acceleration but was a little noisey on the Mways....
Heres a short vid of going round Castle Combe
Post by AutotestAddict on Apr 26, 2017 14:04:50 GMT
I'm pretty sure mine is 4.6 in addition to the stupid wheels.
It is predictably excellent at autotests and similarly predictably horrendous on the motorway.
