Post by jackmorris205 on May 28, 2017 15:03:57 GMT
Ever since i've had the 5 its made an intermittent, very strange screeching noise that i believe are made when the fans kick in, it will make the noise on command when i press the a/c button so guessing it is the fans. Anyone have any suggestions before i just look for new fans? Are they at all serviceable? seem to be working okay, but obviously due to this strange warm weather it does it a lot more and it is rather annoying/embarrassing
Post by Horney on May 28, 2017 15:41:52 GMT
Probably the alternator belt needs changing. Putting the AC on puts extra load on it which will cause an old belt to slip and squeak.
Post by jackmorris205 on May 28, 2017 16:47:58 GMT
I dont think its the belt, its not the typical belt noise, plus I've changed all the belts so it shouldnt be that I've never heard anything like it, if i had a video to hand it would help im sure haha
Post by jackmorris205 on May 28, 2017 18:57:27 GMT
Aha, found a video on the interballs, its a honda but the noise is the same, except mine sort of 'blips' instead of sustaining the noise like the video
Post by atlex on May 28, 2017 20:20:28 GMT
sounds like the fan is going out. or making contact with the side housing ? actual belt noise is much screechier. that sounds like a broken electric motor....
Post by jackmorris205 on May 29, 2017 17:12:41 GMT
No contact that i could find, thanks for the input chaps, probably best to just throw new fans at it, wanted section here I come!
