Post by wannabe on Jul 30, 2019 17:07:28 GMT
wannabe - I guess a balance of low wear (at all temps) and good flow for cold weather performance ? ^
If you remove the title rows and the blank rows, freeze the header/title rows, then sort by value, you can play around a bit.
If you do a three-level sort, you can:
- sort by the 'wear at 100degrees' column as the first sort, then 'wear at normal temperature' column, then 'wear at 200degrees', which I think is probably the correct sequence for someone that does 'normal' driving across the year in a range of temperatures, with minimal track use?
...or...
- sort by the 'wear at 100degrees' column as the first sort, then 'wear at 200degrees', then 'wear at normal temperature' column, which I think is probably the correct sequence for someone that does 'normal' driving across the year + some 'fast road driving' + a few track days?
That first sort gives the "Tailgate McNoIndicate TwinPower Turbo LongLife-04 5W30" as the top result (0.01 @ normal, 0.01 @ 100degrees, 0.06 @ 200degrees), which is interesting. I dread to think how much it costs if it's a Tailgate McNoIndicate oil! lol (But 5w30 might be a bit thin at hot/running temperature for NA/NB engines?)
Some others that seem balanced across the range of temperatures seem to be:
- "Mobil 1 New Life 0W40" - 0.02, 0.02, 0.03 - but is likely too thin at cold start-up on NA/NB?
- "Total Quartz 7000 10W40" - 0.03, 0.02, 0.05 - looks suitable for 5s?
- "Liqui Moly Synthoil Energy 0W40" - 0.04, 0.02, 0.04 - but again might be too thin at cold start-up.
- "Red Line 5W50" - 0.03, 0.01, 0.02 - looks like it might be a good one for turbo engines, which IIRC often have thicker hot ratings recommended?
I guess all of the oils must be pretty reasonable or they wouldn't be sold, lol, and I imagine the tests undertaken are harsher (in terms of perpendicular mass/weight load onto a piece of metal being tested) than you might get in an engine, in order to demonstrate wear rates within a short timeframe...
So, I'm looking for oil for the missus' car...
Coming back to the post above from 10th Jan (link: mighty5s.com/post/38118/thread) there are a couple of other options that could be considered!
- Total Quartz 7000 10W40 still looks good
- Red Line 5W40 has wear rates of 0.03, 0.01, 0.02, so very low!
Those are the two I'm going to look at for the 5 next time it needs it - I still have to swap in the Total Quartz 7000 10W40 I bought previously, so will let you know how it runs!
EDIT: Maybe I won't be going for the Red Line, seeing as it's almost 80 quid off Amazon lol
www.amazon.co.uk/LINE-Performance-Synthetic-Motor-5w-40/dp/B01LOJS2TQ/
The Red Line 5W50 perhaps looks good (i.e. is thicker and probably more resistant to breaking down?) for turbo/SC'd 5s?
The missus car recommends a thinner oil, so either of these look promising:
- Tailgate McNoIndicate TwinPower Turbo LongLife-04 5W30
- Genuine GM 5W30 dexos1 Gen2
Anyway, thank you again for posting the link to the info, atlex!
