Post by stewie on Jul 22, 2017 14:26:14 GMT
How do the nrg wires for horn work/connect on the mk1 with no airbag and single wire for horn.
Post by myothercarsa2cv on Jul 23, 2017 17:48:03 GMT
Horn earths through the boss. Airbag needs some sort of resister to fool it...
Post by atlex on Jul 23, 2017 19:18:37 GMT
Yup - only one wire is needed in most circumstances, but you might need a metal shim to get a decent connection. Show us a pic of the horn button (the rear) - it should have a bit of metal on the side for the earth return, or you can just wire it/solder it for the return.
Post by stewie on Jul 23, 2017 20:20:51 GMT
My mk1 doesnt have airbags. The horn only has the live connector and the ring on side which makes the ground to the hub. The nrg qr has x2 wires hub side to connect and also 2 steering wheel side? Was undure how they pass through?
Post by atlex on Jul 23, 2017 22:20:29 GMT
They pass through isolated by some nylon. It's a good setup. You only need one if the boss is earthed, which it is on a mk1/mk2 :-)
I'm running this same setup on mine. No issues.
Alex
