Post by flood on Sept 5, 2017 13:36:44 GMT
Looking great Wilson, like I said when we spoke I've seen a hell of a lot worse than that so there's a good base for a very nice NA S Ltd there. Looks like Ste is doing a nice job too, he's a good guy. yeah impressed so far!
Post by flood on Sept 7, 2017 16:07:16 GMT
Post by melx5 on Sept 8, 2017 19:08:22 GMT
getting on with it now.... front wing cleaned and protected The bracket I've outlined, is this the one many say can cause problems when removing the wing?
Post by flood on Sept 8, 2017 19:37:13 GMT
getting on with it now.... front wing cleaned and protected The bracket I've outlined, is this the one many say can cause problems when removing the wing? not sure. I know you can bother with the ones at the bottom as they get rusted pretty bad. I am replacing both front wings so as long as bolts dont shear i am ok
Post by flood on Sept 19, 2017 19:50:18 GMT
Dewi
Post by Dewi on Sept 19, 2017 23:50:33 GMT
Impressive! That's how you paint a car
Post by scottydugg on Sept 20, 2017 6:38:17 GMT
Looking very good, what did you protect under the front wings with? I was intending using stone chip or the likes, sneaking in a set of wing braces in at the same time, apparently they make a good difference like chassis rails stiffeners.
Post by minty on Sept 20, 2017 7:05:02 GMT
Very nice!!!
Post by flood on Sept 20, 2017 13:12:42 GMT
Looking very good, what did you protect under the front wings with? I was intending using stone chip or the likes, sneaking in a set of wing braces in at the same time, apparently they make a good difference like chassis rails stiffeners. Cheers. They have used stone chip and they have wax oiled before painting so I should not have to take wing off again
Post by flood on Sept 21, 2017 21:51:55 GMT
Post by flood on Sept 27, 2017 16:55:06 GMT
Post by atlex on Sept 27, 2017 17:31:59 GMT
Lush!
Post by minty on Sept 27, 2017 20:48:52 GMT
Gorgeous! What do you do for a living may I ask?
#Garageenvy
Post by flood on Sept 27, 2017 21:03:37 GMT
Gorgeous! What do you do for a living may I ask? #Garageenvy Thanks i am a basically a transportation consultant... Currently work in Abu Dhabi and focus on transport technology/ Intelligent Transportation Systems with a bit of autonomous vehicle stuff thrown in
Post by minty on Sept 28, 2017 5:03:00 GMT
Gorgeous! What do you do for a living may I ask? #Garageenvy Thanks i am a basically a transportation consultant... Currently work in Abu Dhabi and focus on transport technology/ Intelligent Transportation Systems with a bit of autonomous vehicle stuff thrown in Sounds interesting will the new paint be ok under that cover?
