khare
Post by khare on Jan 15, 2018 15:49:16 GMT
Post by g19doug on Jan 15, 2018 16:29:49 GMT
khare
Post by khare on Jan 15, 2018 20:02:56 GMT
Was the likeliest option mate but I can’t justify having a paddle clutch on a daily.
Post by atlex on Jan 15, 2018 21:15:45 GMT
Post by atlex on Jan 15, 2018 21:19:25 GMT
khare
Post by khare on Jan 16, 2018 18:36:56 GMT
Nice one thanks mate,
Some good options there. Liking the Exedy Stage 1 from mx5parts!
Post by Horney on Jan 16, 2018 19:15:37 GMT
Avoid a paddle clutch. I hated mine on the road. Was awesome on track though.
I’d go Exedy or Skuzzle.
khare
Post by khare on Jan 16, 2018 21:49:41 GMT
Avoid a paddle clutch. I hated mine on the road. Was awesome on track though. I’d go Exedy or Skuzzle. Yeah they’re two two likely options. Heard and read many many good things and reviews of the Exedy clutches.
khare
Post by khare on Jan 16, 2018 21:51:51 GMT
What about lightweight flywheel options? There’s a few I’ve got my eye on (G19 and skuzzle).
Post by Horney on Jan 16, 2018 22:37:35 GMT
Lightened flywheels are ace. My opinion is buy a cast one, not a skimmed down standard one. I believe that both G19s and Skuzzles are proper cast light weight flywheels.
Post by myothercarsa2cv on Jan 16, 2018 23:06:30 GMT
You could get yours lightened (or another lightened to save time, cheap for second hand ones), or either of the above. A few other options available as well eg mx5parts etc.
Post by atlex on Jan 16, 2018 23:30:07 GMT
pewe
Post by pewe on Jan 17, 2018 10:45:22 GMT
Agree with Atlex and Horney on paddle clutches and ultra light flywheels. Originally I put a 4.5kg flywheel and paddle clutch in my 1.6 s/c NA for fast road, track and Solos. It wasn't until I changed it for a 5.2kg flywheel and full section cera-metallic friction disc I realised that the 4.5 set up was unpleasant in that it caused shunt & noise, particularly on the over-run and was pretty snatchy. So far the 5.2 set-up has performed well, even double driven at Solos there's no sign of slip. TBH I suspect a lot of these clutches are sourced from the same factories - its just the branding which is different. HTH. Cheers, Pewe.
Post by scottydugg on Jan 17, 2018 11:06:52 GMT
I've an Exedy clutch and Mazdaspeed lightened flywheel,Exedy seems a quality piece of kit.
If it's a 1.6 you've got, I think someone just listed a lightened flywheel in the for sale ads today on here.
khare
Post by khare on Jan 17, 2018 11:17:24 GMT
I’m definitely after a billet flywheel rather than a standard lightened one, don’t dancy potentially having my ankles chopped by a shattered flywheel.
It’s for a 1.6 but clutch going in is 1.8 size so that Ebay one would be no good. Will pick out the hat between skuzzle and G19.
