Post by jackyboy on Mar 29, 2018 16:46:37 GMT
khare
Post by khare on Mar 29, 2018 21:03:50 GMT
Remember R888 has stiff sidewalls.
I once got a puncture in my rear AD08R (also stiff sides) and drove 20 miles before I noticed it was flat.
Lower pressure on a track tyre sounds right. Road tyres start at 26psi and go from there.
Post by nickd on Apr 4, 2018 15:16:27 GMT
Tyres will take a large range of pressure variation because they have to. Pressures are all about the pressure the tyre is expected to see in service and cold pressures are just a starting point as to where they are expected to get in service. Obviously for the vast majority of road driving, cold pressures are the best and sometimes only way to work this. However don't think that is what it is about. If you set 26psi in 15 degree ambient then when as recently the temps dropped to -8 that pressure will be much lower. Equally just the sun on a tyre can raise static pressure by as much as 5psi So the cold pressure is not the operating pressure. One of the biggest mistakes people make going on track, where the tyre is worked much harder, is dropping to silly low pressures. A hot working pressure on an MX-5 is around 32psi. That is hot off the track, not having stood for 10 minutes. It can go higher. High pressures are a potential indication of a tyre being over worked or the rubber compound not being suitable and over heating. Some drivers will run their tyres in wet race condition as high as 45psi. This is because the stiff sidewall then means the tread moves more heating that better, combating the water which is sucking temp out of the tyre. For sprints, especially hill climbs, set the hot tyre to start with as there is no time for a tyre to build temperature and come up to pressure. Even on whole lap runs of somewhere like Snetterton, still start with a higher than "cold" pressure because the compromise of taking 3/4 of a lap to get to the right pressure is not worth the floppy tyre on that first 3/4. Hot or operating pressures, is what it is all about.
Post by dadbif on Apr 4, 2018 16:41:03 GMT
Good points made there, most motorway blowouts are caused by under inflated tyres, the execessive sidewalk flex super heats the air increasing the pressure and softening the tyre....
Post by atlex on Apr 4, 2018 16:58:24 GMT
I've stickied this thread and put quoted nickd's post because it is very good.
Post by nickd on Apr 7, 2018 1:06:40 GMT
Not quite right, superheated air would increase tyre pressure resulting in a stiff tyre. Under inflated tyres cause the sidewall's to be over worked as excessive heat in them which rests in the sidewall failing.
Post by dadbif on Apr 7, 2018 20:07:36 GMT
As I said, under inflated tyres cause blowouts....
