Post by FFS Corders on Mar 25, 2020 18:21:42 GMT
Way out if date but anyway, here is the outcome of the weekend just gone, swap from mx5parts dual that was rattling at 3k to a Cybox 2.25" single
Post by Zed. on Mar 25, 2020 18:50:42 GMT
anything else planned or is it clean&polish time?
Rich.
Post by FFS Corders on Mar 25, 2020 19:17:45 GMT
Need to fit new hangers as it's clanging against the chassis brace so that's something for this weekend
Then when I get paid I might get the full version of Tunerstdio and see if I can play with my MS2
Post by FFS Corders on Apr 6, 2020 8:22:45 GMT
bit more progress made this weekend when i changed the engine mounts Off came the exhaust manifold for ease of access Then i swapped the new mounts straight onto the brackets after being advised the cup isn't strictly necessary and allow the engine to drop a little (which will help get the strut brace to stop fouling the inlet manifold) Then after the really annoying process of getting the driver's side mount back on (there's literally everything in the way and 4 bolts to line up) i moved onto the passenger footwell In preparation for eventually fitting an MS2, i moved the ECU up into the airbag recess in my mk2 dash. This will allow easier access for tuning the MS2 later on, plus means the damp footwell i discovered won't affect it Getting the wiring loom the loop back past itself behind these 2 units was a huge pain (in some cases literally, got some nice scratches up my right arm from reaching past all that lovely metal), then i cut the bottom off the airbag cover so it would fit back on But it was worth the effort, just need to figure out a method of fixing it down Next weekend hopefully the weather will be good and i'll have received the poly exhaust hangers which should stop the exhaust clanking against stuff
Post by dadbif on Apr 6, 2020 12:21:26 GMT
Good idea, mine is still in the footwell. Make yourself a nice long USB lead that you can leave permanently connected to the MS and tuck out of the way, mines about 5ft long, then you can easily play with Tunerstudio whilst fiddling under bonnet, or if you’re dead posh get the Bluetooth thingy
Post by FFS Corders on Apr 6, 2020 12:31:52 GMT
Got myself an extended ftdi cable from BOFI ages ago, so that's ready to put somewhere around the glovebox area or down where the bolt cover is...need to work out where the IAT is going yet and purchase/borrow a tap and die to out a thread for it into the intake pipework
Post by FFS Corders on Apr 9, 2020 15:35:39 GMT
These arrived during the week, so got something to do during the long weekend
Post by FFS Corders on Apr 10, 2020 11:40:39 GMT
Actually scratch that, need new gaskets on the cat
Post by FFS Corders on Apr 10, 2020 17:09:57 GMT
Decided to go for it anyway...those poly hangers are a nightmare to fit! had to file down the knob end of the brackets on the car to get them to fit on. Also i think this comparison with mx5parts exhaust on the bottom and cybox on the top explains partly why i'm having issues then here is the result of fitting it back on... So i gave up with that idea and threaded the vac line into the new ECU location instead That'll do for a bit. need to wait for pay day now and i can start working out what parts to get next
Post by dadbif on Apr 10, 2020 21:00:10 GMT
Oil the rubber hangers, they slip on easily then!
Post by FFS Corders on Apr 10, 2020 21:14:39 GMT
With these being poly, they don't stretch quite as much as rubber ones...so had to give it smaller area to expand to! Oil did help so much though, didn't do much for my grip on them though
Post by dadbif on Apr 11, 2020 7:59:20 GMT
Use mole grips or water pump pliers, make the bastards have it!
Post by JamesMk3 on Apr 11, 2020 16:45:31 GMT
Washing up liquid works wonders for this kind of thing
Post by FFS Corders on Apr 12, 2020 20:39:09 GMT
Put these on today, need to decide what colour to make them as they need a bit of refurb. Leaning towards a slightly darker silver than they are now, but very tempted by gold
Post by Dweenimus on Apr 18, 2020 12:44:39 GMT
Gold ftw! If you want to abandon lockdown and test fit my goldies. I already have two off the car while doing bushes
