Post by FFS Corders on Apr 18, 2020 14:50:35 GMT
I'm in no rush lol, I can keep having a dilemma for a few weeks yet Exhaust gaskets arrived yesterday, might fit them at some point but won't be this weekend Also put the vac line onto the nipple just behind the throttle body, that'll do for now
Post by FFS Corders on Apr 25, 2020 23:25:56 GMT
Today did not go well
Bought tunerstudio and megalogviewer, plugged in the MS2, out the serial to USB adapter to my laptop....Tunerstudio can't find the ECU
OH BALLS
now I am going to try my ancient laptop from 2008 instead in case it's a laptop problem. If not I'll try the ME221 I have spare in case it's an ECU problem
Post by Zed. on Apr 26, 2020 10:25:37 GMT
Tunerstudio can't find the ECU ignition on (powering the ecu?) Rich.
Post by FFS Corders on Apr 26, 2020 10:32:04 GMT
Yep and the battery is charged and connected to the car
Post by Zed. on Apr 26, 2020 10:33:29 GMT
hammer?
fire?
Rich.
Post by Zed. on Apr 26, 2020 10:36:17 GMT
plugged in the MS2, out the serial to USB adapter to my laptop....Tunerstudio can't find the ECU sometimes you have to 'find' the correct port on a windows craptop to connect? common on usb - OBD2 dongles Rich.
Post by FFS Corders on Apr 26, 2020 10:40:33 GMT
Its on COM3, which tunerstudio looks for while it cycles through its ECU search. Tried both baud rates it searches for with no luck
Apparently some laptops just won't connect for whatever reason, so trying with a different one
Post by Zed. on Apr 26, 2020 10:49:01 GMT
hammer & fire then for the laptop Rich.
Post by FFS Corders on Apr 26, 2020 13:23:44 GMT
Ok short update Remembering to disarm the immobiliser means the ECU receives power. Laptop can now see it
Post by FFS Corders on Apr 26, 2020 19:37:51 GMT
While I build up the will to work out how to wire the AEM wideband into the stock O2 plug then gut a MAF and drill a tap for the ait, I have stopped for now safe in the knowledge the TPS is calibrated
Post by FFS Corders on May 4, 2020 10:01:29 GMT
Right, got round to doing a few more things over the past week. First was making sure the ECU was still talking to the laptop just fine Next up was pulling wires through the firewall into the airbag cubby hole. This was a pain as the hole i had available was only just big enough to fit the small AEM connector through, so some filing occurred and success was made. Both AEM wire bundles and the MAP line now going neatly through one hole. I also took the opportunity to cut down the white/black, green and blue wires on the AEM loom and fold them back into the wrapping as they aren't needed and would only confuse me AEM were also extremely generous on their supply of wire length! Then it was time to start wiring up the AEM wideband and the fancy "5 times faster than OEM" AIT First up i had t work out which wires to use from the original O2 sensor. This was a major ballache given I have a 4-wire sensor in my 1994 1.8 loom and there was little to no definitive help out there. Luckily, asking on Facebook and much reading of wiring diagrams showed that i needed the Red/Blue and the Black/Blue wires on the loom, which correspond to the blue and white wires on my 4-wire O2 plug Having read the wiring diagram supplied by AEM and receiving help from Facebook (specifically Spanner and Hammer Speed Shop who are documenting their MX5 build in excellent captioned-photo detail) i soldered the brown AEM wire to the white O2 wire and the white AEM wire to the blue O2 wire; the two black wires remaining on the O2 sensor loom i just cut short again for reduction of confusion purposes Next i fitted a ring terminal to the black AEM wire and put it under the ground block for the ECU amongst other bits that go into here Finally the red AEM wire was soldered to the very convenient switched 12v live of my RPM switch Next was time to fit the wideband sensor to the exhaust...easy as undoing the old one and replacing it Then after moving a brake pipe out of the way, i fed the wiring through to the connector i had fed through the firewall and pushed it together Gauge is now sat next to the ECU ready to be used for some road tuning Next up was getting ready to fit the AIT (air intack temperature) sensor, which involved removing my jackson racing intake....and this roll of toilet paper that must have been in there since JAE last year Out came the MAF and the hacksaw, which produced this work of art ready to be drilled and tapped for the M12 x 1.5 thread of the AIT And finally,i didn't quite get to the finish line with this one - found an old 2-pin connector pair in my pile of random junk i keep hold of, so the two AIT wires went in one end, with the other end to be soldered onto the Red/Black and Black/Green wires on my 1.8 MAF loom (can be any way round as polarity of the sensor is irrelevant, but given i have a red and a green wire it sort of suggests itself) So now all i need is to add the AIT into the mix, hook the freshly charged battery back up, then i can actually try starting the car
Post by dadbif on May 4, 2020 11:01:29 GMT
Don’t forget a grommet where your cables pass through the bulkhead.
Post by FFS Corders on May 4, 2020 11:04:19 GMT
Thanks, was thinking how to achieve this now they're in...think it will be a case of essentially lining the outside of the hole with a cut up one and using some sealant round it
Post by dadbif on May 4, 2020 13:25:33 GMT
Just cut it, it won’t fall out once it’s in place
Post by dickie on May 4, 2020 15:34:44 GMT
You could have just cut the plug off the old O2 sensor and connected the AEM wideband straight onto the plug and plugged it back into the cars loom. Its simple and it works. As far as grommits got cutting them and installing is easy. I have cut larger grommits taken a section out so that it fits a smaller hole. Just use a sharp blade to make it neat.
