Post by binner on Oct 14, 2021 8:31:02 GMT
hello,
is it possible to adjust the position of the accelerator pedal or am I going to have to bend/cut/weld it ?
i used to have a mk1 in which the stock pedals position worked pretty well for heel and toe.
In my mk2.5 the accel is too far away from the brake to be able to reach with my little feet.
any experience or advice welcomed
Post by Zed. on Oct 14, 2021 9:22:33 GMT
i used to have a mk1 in which the stock pedals position worked pretty well for heel and toe. In my mk2.5 the accel is too far away from the brake to be able to reach with my little feet check that the pedalbox hasn't cracked & the throttle-pedal mount (& pedal) isnt about to fall off am I going to have to bend/cut/weld it easily done Rich.
Post by noobie on Oct 14, 2021 9:42:24 GMT
In my mk2.5 the accel is too far away from the brake to be able to reach with my little feet. Or try and find a larger accel-pedal cover and bolt/epoxy/stick it a bit closer? Probably already exists on the market.
Post by binner on Oct 14, 2021 9:42:47 GMT
check that the pedalbox hasn't cracked & the throttle-pedal mount (& pedal) isnt about to fall off easily done Rich. I will check the pedal box though I think it is fine. I have the fabrication skills of a newborn baby so it will be easily messed up by me
Post by Zed. on Oct 14, 2021 10:01:45 GMT
check that the pedalbox hasn't cracked & the throttle-pedal mount (& pedal) isnt about to fall off easily done Rich. I will check the pedal box though I think it is fine. I have the fabrication skills of a newborn baby so it will be easily messed up by me iirc, pedalboxes are interchangable from 1989-2005 so replacements are available cheaply, not a hard job to remove & replace (have one to change on a friends 1990 Eunos as it's neen 'RePaIrEd' by someone writing braille - will take photos but won't be soon...) Rich.
Post by wannabe on Oct 16, 2021 12:58:14 GMT
In my mk2.5 the accel is too far away from the brake to be able to reach with my little feet. Or try and find a larger accel-pedal cover and bolt/epoxy/stick it a bit closer? Probably already exists on the market. +1 Something like this but with a tab/tongue that sticks out on the left of the accelerator pad? www.mx5parts.co.uk/aluminium-pedal-cover-mazda-mk2-25-p-2039.html
Post by binner on Oct 20, 2021 15:24:00 GMT
thanks wannabe and noobie , I will try the moss ones as they are local to me , the yhabve one for the auto which has a much bigger brake pedal
Post by atlex on Oct 20, 2021 20:22:11 GMT
Buy some aluminium bar 5mm thick and make what you need out of that ? drill, countersink, nut on the back countersunk bolt in the front, sorted....
Post by atlex on Oct 21, 2021 8:28:05 GMT
Buy some aluminium bar 5mm thick and make what you need out of that ? drill, countersink, nut on the front countersunk bolt in the front, sorted.... FYI: This is precisely how the M2-1001 aluminium pedal covers are made and attached to the existing pedals. See: mazdaroadster.net/showthread.php?17146-M2-1001-Factory-Pedal-Set-of-(4)Considered the best pedal covers made for the NA and NB.
Post by binner on Oct 22, 2021 11:26:28 GMT
Buy some aluminium bar 5mm thick and make what you need out of that ? drill, countersink, nut on the front countersunk bolt in the front, sorted.... FYI: This is precisely how the M2-1001 aluminium pedal covers are made and attached to the existing pedals. See: mazdaroadster.net/showthread.php?17146-M2-1001-Factory-Pedal-Set-of-(4)Considered the best pedal covers made for the NA and NB. I would love to but I don't have any of the required tools or skills. The moss pedal set will achieve the same thing
Post by Zed. on Oct 22, 2021 18:15:01 GMT
Buy some aluminium bar 5mm thick and make what you need out of that ? drill, countersink, nut on the front countersunk bolt in the front, sorted.... FYI: This is precisely how the M2-1001 aluminium pedal covers are made and attached to the existing pedals. See: mazdaroadster.net/showthread.php?17146-M2-1001-Factory-Pedal-Set-of-(4)Considered the best pedal covers made for the NA and NB. Think I've 2/3 (throttle & one pedal pad) of that type in the shed.... Rich.
Post by binner on Oct 25, 2021 14:58:42 GMT
Think I've 2/3 (throttle & one pedal pad) of that type in the shed.... Rich. Cool, I have ordered some cheap stuff from Demon tweeks ,let me know if you have yours as I like options :-)
