Post by zoona on Aug 16, 2022 10:12:13 GMT
also did you try disconnect your boost gauge ? Yep. Took that out of the equation yesterday. Will try bov this morning. Then it is only expensive bits ..
Post by atlex on Aug 16, 2022 12:42:39 GMT
btw would you make a more *cough, trying to sound northern* substantial video of the sound ?
did you try spraying your belts with water then driving, also ?
Post by zoona on Aug 16, 2022 15:34:27 GMT
btw would you make a more *cough, trying to sound northern* substantial video of the sound ? did you try spraying your belts with water then driving, also ? Will do. Have cobbled together the parts to pressure test it from the turbo downstream. Just going to try that out and see what happens. I took the bov to pieces, cleaned out up and reversed out. It all looked ok, but new o rings would be better.
Post by howardb66 on Aug 16, 2022 16:58:56 GMT
A friend of mine had a boost problem on his MX5 very recently. It turned out to be a nut on the T piece take off for the boost gauge was only finger tight, was leaking about 10 psi…
Edit: noticed on you vid, the boost gets to 0.7 bar- is that what you expect?
Post by zoona on Aug 16, 2022 19:30:17 GMT
A friend of mine had a boost problem on his MX5 very recently. It turned out to be a nut on the T piece take off for the boost gauge was only finger tight, was leaking about 10 psi… Edit: noticed on you vid, the boost gets to 0.7 bar- is that what you expect? THis is exactly the question i have been asking myself, and I'm ashamed to say i don't tknow. It felt like it should have been carrying on building boost at that point. I have, however answered that question as I have fixed the issue... I should expect more than that! I have basically take every single piece of the intercooler piping apart and put it back together. The bit that annoys me is that I don't know exactly which part it was... I think it might be time to renew it all anyway - particularly the clamps which are pretty rusty. Thank you all for your help as usual. I got to the problem in the end...
Post by atlex on Aug 16, 2022 21:15:51 GMT
Sounds like you slew the beast!
Post by zoona on Aug 16, 2022 21:22:41 GMT
Sounds like you slew the beast! I think i just bored it to death.
