Post by binner on Apr 24, 2023 9:33:08 GMT
Hello,
I am going to go for 16x8 wheels (et35 min) so I can use Conti PC6 tyres with a little stretch in a 205/45/16.
I currently have 15x7 Oz Superlegeras which are featherweight (4kg per corner without the tyre IIRC)
Is there a 16x8 rim that is less than 7kg that costs less than £1k for a set of 4
Most of the options are fearsomely expensive.
Team dynamics pro 1.2 ;looks like a reasonable compromise
or a second hand set of rota cups
what does the hive mind think ?
Post by atlex on Apr 24, 2023 9:43:18 GMT
Post by atlex on Apr 24, 2023 9:51:00 GMT
Post by binner on Apr 24, 2023 10:08:59 GMT
those Konigs are spendy !
If there were better tyre options at 15in I would try to stick it out but the PC6s seem to have better grip. I cannot run list 1b due to regs and the decent list 1a tyres (PS4, PS4s, conti SC7 ) all start at 17 or 18.
I know my requirement is niche the 16in PC6 seem like a good compromise.
the only downside I can think of is a bit more unsprung weight (4-6kg in total) and steering feel
Post by atlex on Apr 24, 2023 11:24:20 GMT
Yeah there's a lack of 1A UHP tyres for 15" now. Sucks a bit.
Post by atlex on Apr 24, 2023 19:49:46 GMT
jimb
Post by jimb on Apr 25, 2023 8:07:45 GMT
Why not just buy some cheap Mazda wheels, to see if the the advantage is real for pc6?
nb, I do suspect the advantage over ps3's is real, by the way!
Post by atlex on Apr 25, 2023 8:12:32 GMT
Why not just buy some cheap Mazda wheels, to see if the the advantage is real for pc6? nb, I do suspect the advantage over ps3's is real, by the way! the cheap Mazda wheels for 4x100/16" are actually very very very heavy really messing with handling (ask me how I know) and are not wide enough (6.5" wide) and the cost of mounting and unmounting to find out won't be cheap.
Post by howardb66 on Apr 25, 2023 9:01:38 GMT
My Team Dynamics are pretty heavy, the Rota s are much lighter.
Post by binner on Apr 26, 2023 14:57:03 GMT
I had some mazda 16in wheel when I bought the car they were indeed very heavy. The rota choice is sliptream or grid , I think the ET needs to be 34 or higher
Post by atlex on Apr 26, 2023 16:04:53 GMT
they're both quite light rotas. so which do you want.. 6 spoke or 5 ?
Post by binner on Apr 26, 2023 20:38:19 GMT
Choices choices 😄
Post by herrkah on Mar 5, 2024 10:07:31 GMT
Post by atlex on Mar 5, 2024 12:17:24 GMT
