Post by hoodedreeper on Aug 3, 2016 19:14:42 GMT
I haven't cleaned up the rear arms enough to see if there are any markings. They could be Megan Racing? Or eBay specials (more than likely)
Post by hoodedreeper on Aug 10, 2016 20:41:47 GMT
Post by japanesewookie on Aug 10, 2016 21:20:21 GMT
Love the new one. Like the skinny wheels and how simple it is.
Post by atlex on Aug 11, 2016 11:55:59 GMT
nice. very nice.
Post by hoodedreeper on Aug 22, 2016 19:39:22 GMT
Yesterday (Sunday 21st August) myself and a few friends headed over to Santa Pod Raceway for their Run What You Brung events. Having never done this i was pretty nervous... MX5 - 200hp MR2 Turbo - 363hp Astra GSi - 276hp Leon - 325hp It wasn't until my last run of the day that i found the Intercooler pipe on the Charger side wasn't attached. By the time we managed to get it fixed the track had closed. The times aren't the best for the car spec,but i now have targets to beat for next time
Post by atlex on Aug 22, 2016 22:46:19 GMT
btw mind if I use a pic of yours for an updated banner ?
Post by atlex on Aug 22, 2016 23:33:20 GMT
Post by hoodedreeper on Sept 19, 2016 20:41:20 GMT
No problem On the 10th September it was 3 years since i first got the car Not much has happened recently with the cars,we went to Japanese Auto Extravaganza a week or so ago (UK's largest Jap show) On the way home from the show,the ONLY time i put my foot down (properly) the car decides to break down A massive misfire and lots of smoke Its currently running on 2 cylinders (1 and 3),i've changed the spark plugs,ignition leads,ignition coil and the cam angle sensor. I've checked the timing belt and it hasn't slipped a tooth and the cams aren't damaged. I've also tested the ignitor unit,igniton coil and leads off the silver car and still no change. I'm yet to do a compression test (waiting on a friend to bring it round). All the injectors are working,there's PLENTY of fuel but for some reason cylinders 2 and 4 aren't sparking as good as they should be (plugs look brand new still). Need to check all the wiring too as i'm sure thats the fault,but it doesn't explain all of the smoke when it first happened? (oil getting past the piston rings or dropped valve possibly?!)
Post by atlex on Sept 19, 2016 21:13:04 GMT
are 2&4 sharing the same coil unit ?
Post by hoodedreeper on Oct 16, 2016 15:05:49 GMT
A little update Did a compression test with the engine cold Cyl 1 - 140 Cyl 2 - 120 Cyl 3 - 135 Cyl 4 - 120 I understand its low,but surely it should still fire on all 4? I've sent the injectors to Clive at Autotronix who cleaned and flow tested them and they've come back fine. Today (Sunday 16th) i refitted the injectors along with a replacement fuel rail and fuel pressure regulator. We tested the injector pulse with an LED,cylinders 1 and 3 pulse fine but 2 and 4 (the ones i've got problems with) are constantly on. With the ECU removed,i got my friend to open it up and found one of the Injector Driver looked damage,see photo below Above and to the left of the driver is abit brown so its gotten abit warm at some point. Reverant from MX5Nutz who built and supplied the Megasquirt ECU is looking into it and i'm waiting on a response At least i've finally found the issue and hopefully have it sorted soon. Once its running again,i need to address the low compression and hope it hasn't washed the bores too much
Post by joeytalent on Oct 17, 2016 18:42:08 GMT
Interesting - one of my friends running a Reverant MS2 on a turbo car and had the same problem.
Post by hoodedreeper on Oct 18, 2016 17:12:42 GMT
Did he manage to repair the ECU ok? Any further issues with the ECU?
Post by joeytalent on Oct 18, 2016 20:57:41 GMT
Yeah, he sent it off to Rev, got it back fairly quickly. As far as I know, it's still running absolutely fine - he had it mapped on a dyno and did a few drift days.
Post by atlex on Oct 18, 2016 21:15:18 GMT
somebody let the pixies and smoke out of that chip
Post by hoodedreeper on Dec 9, 2016 19:14:40 GMT
So after almost 3 months of trying to fix the car i gave in and dropped it off to H&S Performance for them to look at it. Within 20 minutes they had it running.
Y'know how you kick yourself over something ridiculously simple/stupid? Yeah i'm doing that...alot!
Fuel lines were opposite way round on the fuel rail. The fuel pump wiring was earthing out too. So add those to the damaged injector driver on the Megasquirt and there we have it!
They're gonna do an oil and filter change and run it round the block to make sure its all ok.
Easy mistake to make,you live and learn!
