Post by atlex on Feb 19, 2017 9:24:06 GMT
FWIW.. why are you shifting the intercooler back ?
Post by onepaintedman on Feb 19, 2017 9:49:27 GMT
2.5 inch pipes won't clear the bonnet without cutting holes in the bonnet if it's mounted further forward.
Post by onepaintedman on Feb 19, 2017 18:14:42 GMT
Feck it. . . Did some more today. Need to drop the intercooler one more inch and we're golden. It all clears the bonnet when closed but I want the pipes to align to the charger and inlet manifold a little better. Recharged the battery on the Range Rover today and the gearbox issue seems to have spontaneously disappeared? So no bus for me. . . for now.
Post by atlex on Feb 19, 2017 19:09:31 GMT
that looks professional drew!
also.. "LOL modern car problems" re gearbox issue solved by battery recharge.
Post by onepaintedman on Mar 1, 2017 20:19:25 GMT
Installed an IAT sensor boss on the output leg of the intercooler. I don't own any taps so had to get creative. I had a screw in hose tap that I originally bought for the purpose but now don't have any run of silcone hose to install it in! So I bonded the threaded lock nut on to the end of the external thread with some liquid metal and then cut it off. This left me with a 4mm thick internally threaded boss. Then I drilled a slightly larger hole than the internal thread of the boss in the wall of the output leg of the intercooler to run the sensor through. . . . . . and bonded the boss to the outside using JB Weld. Nice and neat and places the sensor perfectly when screwed in! In other news - had to be recovered in the the Range Rover last week following total loss of drive. It has now had a battery change (as the old one was fubar'd) but 'drive' is occasional and temporary. It is now booked in to a local Land Rover specialist next week for diagnosis. I expect to be broke again soon!
Post by myothercarsa2cv on Mar 1, 2017 22:09:50 GMT
Neat solution to the IAT install. It's all coming together nicely!
Post by onepaintedman on Mar 4, 2017 18:03:27 GMT
. . . and I'm back in the game. Started up, warmed up and settled to a nice steady idle. Went for a spin. OH MY LIFE! What a difference! I confess I haven't even installed the yellow injectors yet because I was in desperate need of getting the car back on the road (My wife and kids have had to run me back and forwards to the station every day as my Rangie is yet to be fixed). But wow, so much smoother and quicker with the intercooler and the 150mm crank overlay. I was laughing maniacly like a Bond villain! I'm seriously happy. Had a little issue with the coolant boiling but that was down to an airlock and soon sorted. Can't wait to get back out in it!
Post by onepaintedman on Mar 15, 2017 6:39:59 GMT
Radiator cap was off because I was bleeding air after refilling the coolant.
Post by onepaintedman on Apr 2, 2017 15:51:42 GMT
Rangie is finally back after being fixed. Man, I missed that car. Had to have the gearbox completely rebuilt and a repair to the transfer box - £2400. Ouch. The guys at STA Auto transmission specialist Aylesbury run a tight operation though and the cleanest workshop I've ever seen!
I've now started yet another mod to Ronins dashboard!
Post by onepaintedman on Apr 16, 2017 20:35:52 GMT
Balls. Accidently pulled my dash switch panel off the crash pad today. Now sulking.
Post by atlex on Apr 16, 2017 21:04:27 GMT
So it pushes you to find a better way to attach it :-).. heh. holy fook re: rangie gearbox price.
Post by onepaintedman on Apr 17, 2017 10:48:26 GMT
Yeah - going to have to sort out a more permanent method of attachment.
Might get the spanners out this evening and bung the RX8 injectors in whilst I work out a way to do that.
Post by onepaintedman on May 7, 2017 8:44:46 GMT
Dash still in pieces but I've decided to fit the RX-8 injectors today as I have been procrastinating about it for ages.
I need to do something to get me away from t'internet. I've been obsessively searching for an Alfa Romeo V6 (75 or GTV Cup)!
Post by onepaintedman on May 7, 2017 16:27:23 GMT
FFS - just snapped off one of the 12mm bolts in my fuel rail as I was undoing it
Post by atlex on May 7, 2017 20:22:04 GMT
ouch! did you manage to get it out still ? what went wrong ?
