Post by onepaintedman on Feb 21, 2022 11:52:11 GMT
Post by onepaintedman on Feb 21, 2022 11:53:08 GMT
He's in a very sorry state ☹
Post by onepaintedman on Feb 21, 2022 11:56:52 GMT
Hope you bring it back! btw your images aren't working but it looks like the fault of amazon cloudfront/s3. Thanks - my battery went flat before I could fix it. Sorted now!
Post by onepaintedman on Feb 21, 2022 13:20:37 GMT
Walbro fuel pump being delivered later this week.
Hopefully that will help get Ronin running again.
Post by atlex on Feb 21, 2022 14:52:02 GMT
I've still got the corns I bought off you :-) the one exhaust I won't sellThis year after the white car's bumper is sorted, MOT passed, etc, I will run it again. The hills are alive with the sound of..
Post by onepaintedman on Feb 21, 2022 15:53:11 GMT
Wow - I'd forgotten about that. Fruity exhaust that one!
Post by howardb66 on Feb 21, 2022 16:09:25 GMT
That deserves a little tlc. 🙂
What was going on with the instruments? The rest of the interior looks spot on (except for the top of the door cards).
Looks like this has had a lot of your time & cash on it. It’ll be great once again👍🏻
Post by onepaintedman on Feb 21, 2022 18:21:49 GMT
Yep. Around 12 years of blood sweat, money and tears went into Ronin. My other cars took the lions share of available contents from my wallet though and he sadly got side-lined (Much to my regret).
I've had several attempts to try and resurrect him, but too many distractions (and other cars) got in the way.Now I'll have to put some proper effort in to get him sorted, before he deteriorates any further. It's unfortunately become a much bigger job due to my neglect.
The biggest issue atm is not being able to get him started! Once that's addressed I have all new pads and discs to fit and then need to get the windscreen wipers working so an MoT is possible!
The instrument binnacle is missing as I removed my K.G. Works gauge cluster and custom Revlimiter gauge faces to protect them from the damp.
Post by lowender on Feb 21, 2022 19:56:43 GMT
I've always liked this car. Well worth bringing back from the brink. Good luck!
Post by onepaintedman on Feb 24, 2022 18:53:25 GMT
Installed the new Walbro GSS250 fuel pump this afternoon. Still not priming though.
Must be the relay, or I have some other unknown electrical issue.
It was fun tinkering with Ronin again after such a long time though. . .
Post by atlex on Feb 24, 2022 22:05:32 GMT
check the B6S8 ? It's my favourite to check first.
You can open it up and clean the two contacts with a strip of paper soaked in contact cleaner (or carb cleaner).
Post by onepaintedman on Feb 25, 2022 10:19:44 GMT
Relay isn't working (No click). Pump primes when jumped to ground in the diagnostic box.
Still won't start though, even with the pump running. Had one big backfire, so obviously getting a spark. Pulled the plugs (they are new) and they were wet, so no fuel blockage.
Scratching my head now.
Post by zoona on Feb 25, 2022 11:45:39 GMT
check the B6S8 ? It's my favourite to check first. You can open it up and clean the two contacts with a strip of paper soaked in contact cleaner (or carb cleaner). I opened mine up and it was a bit of a state. I had other problems... But this definitely needed a good spring clean too...
Post by onepaintedman on Feb 25, 2022 13:36:30 GMT
Put a spark plug tester on #1 plug. No spark.
Replaced the coil pack (had a spare in the garage) and still nothing.
I hate electrical issues.
Will plug in the laptop and see if the MegaSquirt ECU is ok.
Post by atlex on Feb 25, 2022 14:15:32 GMT
a click may not be enough, I've had one that clicked but wouldn't give enough current to run the pump properly (low fuel pressure).
ignition/timing if you do have some fuel on the plugs. cas ?
also did you check the big ignition relay under the dash ? it's much bigger than the B6S8, I think it's called B577.
