Post by superdan on May 5, 2016 21:20:53 GMT
MK1 trackday car lowered (not excessivley) on coilovers. Looking at getting 15 inch wheels and cladding in 195/50/15 trackday (Nankangs probably or Federals).
I know stock 15 inch wheels are 6J et45, 4x100. Some wheels I'm looking at are 6.5J et35, I can't get my head round the offset and whether the variation in offset helps equalise the difference in width or makes it worse?
Anyway, would 6.5J et35's 'work'?
Many thanks.
Post by superdan on May 5, 2016 21:45:38 GMT
Post by Horney on May 5, 2016 22:10:25 GMT
In the pic in my signature below my car is fitted with 15x7 et 25 wheels with Federal 595 RSR on. No problems at all.
Post by Vindi (Russell) on May 6, 2016 8:25:03 GMT
15 x 6.5 ET35 will be fine, even if you were exceptionally low. Mine are 15 x 7 ET30 and clear with plenty of space
Russell.
Post by atlex on May 6, 2016 10:03:37 GMT
I love posting this picture. These are 6.5"wide 15" wheels on 195/50 tyres. ET35. 5mm spacing rear, 10mm spacing front, all for calliper clearance rather than arch clearance - Bags of space...
Post by superdan on May 7, 2016 12:06:37 GMT
Really appreciate the help chaps! Thanks for replies
Post by Horney on May 7, 2016 12:23:06 GMT
No probs. :-)
Post by mattk on May 7, 2016 12:26:15 GMT
15x7 ET28 with 195/50 R888's Nowhere near as low as I could go, but it doesn't rub at all.
Post by superdan on May 15, 2016 6:49:02 GMT
Off to collect some 7J et38's today. If they are as described, hopefully a bit if a bargain. ?
Post by superdan on May 15, 2016 19:35:23 GMT
Think I've done well here. Picked these up today, bar 1 kerb mark, almoast as new with 2x7mm and 2x5mm Toyo Proxes. Should spank them round Blyton next weekend on this;
Post by FFS Corders on May 16, 2016 19:23:29 GMT
mm JDM
how much do they weigh with tyres?
Post by superdan on May 17, 2016 19:02:36 GMT
12.7kg according to my bathroom scales
Is that good or bad?
Post by atlex on May 17, 2016 19:09:01 GMT
Anything under 13KG is good on 15"s in my book (14" and 13" wheels can get even lighter..)
It's very easy to get 15KG+ combos on 15"s wheels.
Post by niklas on May 24, 2016 15:44:37 GMT
My track wheels 15kg's they're a bit wider though (and this was new DMACK's) But the grip is more important for me.
