Post by superdan on Jun 26, 2016 19:17:29 GMT
So I've read bits and pieces on t'internet about modding the AFM (clockspring) as a slightly crude but effective may of gaining a few horses on the 1.6. Trouble is I've seen things that suggest leaning the mix and some about richening it. Car has a full stainless exhaust, manifold through to back and now a K&N cone so breathing should be decent if that makes any difference.
Our car is used exclusively for track use and rarely see much below 4k revs thus any advice for this specific circumstance would be appreciated, links to other threads also handy.
Post by atlex on Jun 26, 2016 19:21:18 GMT
find someone with an AFR to check it doesn't go too lean...
Post by Horney on Jun 26, 2016 21:31:06 GMT
Where you based Dan? Seen skuzzle do this on a few cars on his RR to good effect. I wouldn't want to try it without.
AFM Mod
Jun 27, 2016 8:42:56 GMT
via mobile
Post by superdan on Jun 27, 2016 8:42:56 GMT
Leeds Miles away 😨
Post by wannabe on Jun 27, 2016 12:14:26 GMT
I still don't understand quite how this mod works lol
AFM Mod
Jun 27, 2016 17:39:37 GMT
via mobile
Post by superdan on Jun 27, 2016 17:39:37 GMT
It tricks the ecu to under or over fuel relative to the calibration from factory for the air it's metering. Sounds a touch crude but if it works it works.
A couple of tuners seem to offer more advanced tweaks that do more than a linear more/less fuel with some componentry jiggery-pokery. For a road car this might be the best way forward. I was hoping for a track day warrior '2 clicks richer' or something was the future.
Post by Rickster on Jun 27, 2016 23:18:06 GMT
I did this to my 1.6 (exactly like you say, just tightened the spring a click or two) But I wasn't confident in it so took it to Skuzzle to do properly! As has been said - need to do it with AFR meter really
titch
Post by titch on Jun 28, 2016 1:35:24 GMT
Blink are over Manchester way, they can do it, I believe, bit closer for ya, if you don't fancy the monster trip down to Skuzzle.
Post by wannabe on Jun 28, 2016 13:49:44 GMT
It tricks the ecu to under or over fuel relative to the calibration from factory for the air it's metering. Sounds a touch crude but if it works it works. A couple of tuners seem to offer more advanced tweaks that do more than a linear more/less fuel with some componentry jiggery-pokery. For a road car this might be the best way forward. I was hoping for a track day warrior '2 clicks richer' or something was the future. Ah, cool, cheers! I guess better to run a bit rich than lean out and risk damage.
